Radiator Fan Issues
Old Aug 29, 2015 | 07:43 PM
KwehCat's Avatar
Default Radiator Fan Issues
Hi!
I bought a 2004 Crossfire and found that it didn't have a cooling fan in it, so I purchased a new cooling fan assembly, but when it was correctly installed it didn't work. The coolant light was on, it was found that the fuse had blown, so that was replaced, but the fan still didn't work. So I bought a cooling fan relay and that just came in today, got it installed, and the fan still won't come on and the coolant light is coming on and off again. Has anyone had this issue and could give me some insight on what else could be going on?
Old Aug 30, 2015 | 08:18 AM
Default Re: Radiator Fan Issues
Cooling fan relay ? Do you mean the FCM ( Fan Control Module ) mounted on the DS fender well ?
Have you connected 12v directly to the fan ( observe polarity ) to ensure it works ?
If so, then check for 12V on the big wire at the FCM.
The FCM is controlled by the PTCM module via PWM ( Pulse Width Modulated ) signals, could be these wires.
Last resort is the PTCM ( Power Train Control Module ) itself.
Old Aug 30, 2015 | 10:53 AM
Originally Posted by KwehCat
Hi!
Starting new threads is not the way to get more answers, stay with your original post. It is not like fishing with two, three or more lines hung over the boat. We get confused very easily and then give up entirely.
Old Sep 16, 2015 | 02:42 AM
MAGNATUDE's Avatar
My Fan seized 5 years ago and I could not drive more than a 1/2 mile until my CF would overheat. When it did, it caused my FCM to burn out. I got it fixed with a replacement fan control module and a Dorman OE spec fan.
First thing I did after un-boxing it was to check if the fan worked before installing it.
MiamiTVR
Jan 30, 2016 02:15 PM
81's
Sep 13, 2015 04:34 PM
RiderJC
Sep 7, 2015 11:19 PM
MickeyNasty
Sep 6, 2015 08:29 PM
williammt
Sep 6, 2015 11:23 AM
