Electrical Problem won't start sometimes??
Old Sep 12, 2015 | 07:29 AM
skeet370's Avatar
Default Electrical Problem won't start sometimes??
Okay here we go! 2004 coupe love the car, however this year I have to bring Jumper-cables everywhere I go just in case. I have a problem that sometimes I need a jump start to get the car running. This is what has been done to the car this year.New CPS, new battery and alternator is putting out the correct amps. So why? Please help!
Oh and by the way I make sure I turn everything off before i get out of the car.
Skeet
Old Sep 12, 2015 | 07:46 AM
Default Re: Electrical Problem won't start sometimes??
Check the negative battery cable connection to the fender well.
Old Sep 12, 2015 | 08:07 AM
skeet370's Avatar
I will thank you, if the negative cable is secure them what? This is driving me crazy!
Old Sep 12, 2015 | 09:00 AM
pioneer4x4's Avatar
Skeet
I think you are going to have to start looking for drains. Gat an ammeter and check when everything is off, then assuming you find current flowing with everything off, start pulling fuses until you find the circuit that is live.
Old Sep 12, 2015 | 09:07 AM
skeet370's Avatar
Thanks I will look into that, one question. does the fob send a signal to something in the engine when turn on? could it be the ignition switch? Bad Fob?
Old Sep 12, 2015 | 09:25 AM
robby363's Avatar
When you said you have to jump it sometimes is it acting like it has a dead battery or does it still crank before you put cables on?
Old Sep 12, 2015 | 09:28 AM
skeet370's Avatar
Dead Battery,
Old Sep 12, 2015 | 09:40 AM
maxcichon's Avatar
There is an RFID/transponder chip in each fob. No battery for it, they are assumed to work forever...
Old Sep 12, 2015 | 10:05 AM
Dead Battery,
As pioneer4x4 said, check for battery drain.
1. remove the negative terminal.
2. Hook up an ammeter/multimeter between the negative cable and the negative battery post.
3. you should see somewhere between 15 and 30 Milliamps.
4. If you see considerably more, start pulling fuses one at a time in the under hood fuse panel until you isolate the culprit.
Once you find it, report back.
Old Sep 12, 2015 | 11:32 AM
skeet370's Avatar
okay wil work on and report back
Old Sep 12, 2015 | 12:10 PM
KDW4Him's Avatar
No not if the jumper cables get you going.
Old Sep 12, 2015 | 12:13 PM
KDW4Him's Avatar
And if it were FOB RFID related the symptoms would not change by using jumper cables. It would do the crank, start momentarily, die routine three times then not crank any more.
Old Sep 12, 2015 | 12:15 PM
KDW4Him's Avatar
And while you are looking at things pull the Relay Control Module out and post a pic of the upper three left solder connections.
Old Sep 12, 2015 | 06:01 PM
skeet370's Avatar
Where is the relay control Located?
Old Sep 12, 2015 | 06:09 PM
It is in the box next to the battery. It is the one closest to the engine.
Old Sep 12, 2015 | 06:14 PM
skeet370's Avatar
Okay , thank you
Old Sep 13, 2015 | 07:22 AM
John Webster's Avatar
This happened to me recently. I turned the key, all the lights came on but the car wouldn't crank. Got a jump and got the car home. Took the truck to AutoZone and bought a new battery. Problem solved.
Went to start the car one day and the fob wouldn't unlock the door. Opened the door with the key (setting off the alarm), put the key in the ignition and got no lights and no start. Replaced the battery ( the original battery was the one the car had when I bought it new in 2004, the replacement battery was the second AutoZone battery I have bought that had failed shortly after purchasing). Problem solved.
A couple of weeks later I turned the key, all the lights came on but the car wouldn't crank. Got a jump and got the car home. Checked this forum and found a page titled Mystery No Start. Turns out this is a problem with bad solder joints on the relay control module. Removed the module, found bad solder joints just like the ones in the pictures on the Mystery No Start page, resoldered the joints per the instructions and replaced the module. Problem solved.
I did buy one of those portable jump start batteries with the jumper cables on it that now resides in the trunk but don't expect to have to use it.
The Mystery No Start page is here:
https://www.crossfireforum.org/forum...-no-start.html
Old Sep 13, 2015 | 07:40 PM
skeet370's Avatar
Hi just got back, I broke down while taking the Crossfire to my mechanic. Driving, it stalled shut off! Thank God I was not on a parkway doing 60!!! pulled over and heard a noise of the cooling fans running load really load. Oh by the way No Check Engine Light ON!
Called for a tow and waited about 30 minutes by the time the towed showed up I turned the engine on and it started.
I am going to call the mechanic in the morning.
Old Sep 14, 2015 | 05:30 PM
KDW4Him's Avatar
Now this one has the symptoms of the Crank Position Sensor, the cool down runs OK scenario. Was the new CPS the Bosch?
Old Sep 14, 2015 | 07:46 PM
skeet370's Avatar
No Changed the CPS early this spring. I am happy to report that the problem has been fixed.
I was the Relay Control Module with the solder not making the connection. My mechanic made the correct connection after reviewing the Cross fire Forum.
Kudos to all especially KDW4Him for his opinion in the matter!!
Thank Guys.
Skeet
