Flooding
Old Jan 2, 2016 | 05:54 PM
8ighth Wonder's Avatar
Default Flooding
So, I discovered the trunk in my roadster had about 2.5 gallons or however much water in the bottom. It was enough to completely submerge the modules under the foam. Prior to this discovery I had no alarm functions, doors wouldn't lock manually or by key fob. My top won't go down electrically either. So besides the two modules and possibly the module for the convertible top. Is there anything else I may have to replace/refurbish?
Old Jan 2, 2016 | 05:57 PM
Default Re: Flooding
I believe the tow-away sensor is mounted just to the rear of the locking pump.
Might want to see if it got wet too.
Old Jan 2, 2016 | 06:25 PM
I'm sure it did the water was up to the fix a flat can.
Old Jan 4, 2016 | 05:47 PM
kingdavid54's Avatar
Wow!!!! I am sorry to hear about that;
Was your car in an actual flood or did the truck just leak?
Old Jan 4, 2016 | 05:49 PM
Trunk leak, someone snuck and drove the car, left the window unlatched for the top, it rained in there. I'm sure the top module is shot too
Old Jan 4, 2016 | 05:57 PM
One thing for sure there are plenty of knowledgeable people on this forum that can help get it back in good working order and save you a ton of money, good luck my friend.
Old Jan 4, 2016 | 07:32 PM
I'm looking for the location of the tow away sensor now.
helosixx
Jan 17, 2016 10:22 AM
twboyle
Jan 1, 2016 03:03 PM
tolas007
Jan 1, 2016 09:20 AM
dognut
Dec 31, 2015 05:11 PM
ant_man252
Dec 31, 2015 01:37 AM
