groaning noise when locking doors
Old Mar 3, 2016 | 07:01 AM
daveesrt6's Avatar
Default groaning noise when locking doors
yes, theres a groaning humming noise coming from the trunk when i use to remote locks.
no nonebody in there, just the pump making this noise , last about 8 seconds after i lock or unlock but sometimes it doesnt groan at all.
the locks all work fine even if its groaning.
what could it be ?
thanks
dave
Old Mar 6, 2016 | 03:42 AM
daveesrt6's Avatar
Default Re: groaning noise when locking doors
fixed now , i screwed in the stops on the trunk lid .
Old Mar 6, 2016 | 01:31 PM
Thanks for sharing the solution, so many don't.
Old Mar 6, 2016 | 04:54 PM
Thanks for the solution to your problem as mentioned above/
You may find that the hatch rattles now when you go over bumps. The solution to that would be obviously tightening the screws a little and or a couple of turns of duct tape or Gorilla tape around the catch on the latch, that is the bottom one on the car body.
Old Mar 8, 2016 | 06:49 AM
daveesrt6's Avatar
Still no groaning !
i had to pull the trunk trim out (those clips break easy dont they) and the foam thing and the other foam around the pump , no evidence of water getting to the pump and all wires and air lines tight . I operated the locks several times ,it would groan for 10secs or so each time but lock and unlocked no problem.
Also I noticed a tiny bit of water droplets in the drain plug at the bottom . I had just pressure washed the car so i checked the usual suspects , fuel door gasket , spoiler mount, all good. Pressure washed the cars behind again and checked out the seal , it was the trunk seal leaking a little in , there was a tiny trail o water headed south .
I screwed in the stoppers on the lid to tighten the lid on the seal , put it all back together and Voila the pump is quiet again.
Not really sure what screwing in the stoppers did to stop the pump groaning ? but.. so far so good its quiet.
Lowering the lid stopped Almost all water getting past the seal but not quite with the pressure washer on it.
I will buy a new trunk rubber seal and that little water ingress should stop
trunk lid does not rattle :-)
Old Mar 8, 2016 | 01:27 PM
You are overlooking the obvious : that noise is your wife cause you got out and locked her in AGAIN !
Old Mar 8, 2016 | 02:05 PM
LOL
I think the groan comes from the extra effort to pull the lock closed, the noise coming from the lock mechanism which probably has to reach a switch to say it has locked.
Old Mar 8, 2016 | 04:48 PM
daveesrt6's Avatar
[QUOTE=ala_xfire;861256]You are overlooking the obvious : that noise is your wife cause you got out and locked her in AGAIN ![/QUOTE
Nah she got locked out years ago
dpbayly
May 15, 2020 10:36 AM
4406bbl
Oct 26, 2016 09:43 AM
4406bbl
Feb 11, 2016 06:27 PM
4406bbl
Feb 10, 2016 09:14 AM
spoiler
Dec 22, 2015 09:23 PM
