Tow away light and fog/taillights flashing.
Old Oct 31, 2016 | 05:07 PM
Padgett's Avatar
Default Tow away light and fog/taillights flashing.
Came home after lunch and a few errands. Noticed at last stop remote did not want to unlock so used key.
When shut down I noticed the "anti-towing" light (rocker next to unlock), fogs, and taillights flashing. Pressed button and nothing happened. Started a few times with key and seems to have gone away.
Description is on page 210 of '07 owner's manual but have not a clue what would set it off other than my driveway is moderately steep.
What is "the transmit button on the key fob" ? YWYK
ps replaced the battery a few months ago.
Old Nov 1, 2016 | 09:04 AM
zip439's Avatar
Default Re: Tow away light and fog/taillights flashing.
Moisture in the area under the trunk near air pump. SKREEM module. You know the routine; use the search box.
