CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Troubleshooting & Technical Questions & Modifications (https://www.crossfireforum.org/forum/troubleshooting-technical-questions-modifications/)
-   -   Frustrated! Car won't start!! (https://www.crossfireforum.org/forum/troubleshooting-technical-questions-modifications/78860-frustrated-car-wont-start.html)
SoonersFan Aug 28, 2018 12:39 PM
Hello Forum!
Hoping someone can help. I have a 2004 Crossfire that is cranking but won't start. I replaced the battery in June, so I know that's not it. Any idea as to what the problem is?
Also, I'm having the dreaded sticky key problem and was wondering if there was a temporary fix to it? I'm going to try and fix it myself when the weather cools off here in AZ, but for now I'm hesitant to go anywhere for fear of being stranded. Someone suggested spraying something inside. Bad idea??
Thanks for your help!!!
ZERACER Aug 28, 2018 12:49 PM
Re: Frustrated! Car won't start!!
Won't start as in doesn't crank, cranks but doesn't start or starts and the then dies? Each discription means differant things. As for the sticky key lubrication, I don't know.
SoonersFan Aug 28, 2018 11:24 PM
It cranks but then won't start. You can tell it's trying, but just can't. As I said, the battery is new so I don't believe that's the issue at all.
pizzaguy Aug 28, 2018 11:44 PM
The fix for the sticky key is to fix it as per the instructions that I'm sure you have already found here. If you spray WD40 into the tumblers it can't get to the wedge/cam area where the issue is - go ahead and try it - but you are setting yourself up for a "Dr. Phil" moment. If you let it go and it locks up, you will have bought yourself a LOT more grief than just getting in there and fixing it now, while you can.
A crank but wont start can be:
  • Bad crank sensor
  • Bad cam sensor
  • Bad fuel pump (How's the fuel pressure?)
  • Bad fuel pump relay (How's the fuel pressure?)
When you say "it's trying", I do wonder what that means. Sounds like an important clue, if it is hitting on only a few cylinders, or running lean, could be bad gas or (again) low fuel pressure.
© 2026 MH Sub I, LLC dba Internet Brands
