Help me chase vibration please
Old Jan 9, 2020 | 01:24 PM
Superfragl's Avatar
Default Re: Help me chase vibration please
I used an angle gauge. I have electronic version from Harbor Freight.
Put it on front driveshaft and measure the angle, then put it on rear driveshaft and take measurement. Now you can calculate the angle between the two.
Then I took the driveshaft off and put the angle gauge on the transmission flange, take the measurement and calculate the angle between transmission and front driveshaft, then same for rear differential flange and rear driveshaft. I the end I found the 3 angles in the drive-train. Based on feedback from SLK owners, the issue is usually in the rear angle. There are two spacer- washers under differential mount, by removing one or two you can adjust that angle.
Blaiseshimmer
Jun 15, 2012 10:23 AM
special_kxoxo
Dec 27, 2009 07:27 PM
Maxwell
Aug 14, 2007 12:16 PM
Thirteendog
Sep 15, 2006 02:15 AM
Thirteendog
Sep 10, 2006 08:01 AM
