Technical support
Old Jun 1, 2020 | 11:39 AM
Ifecollins's Avatar
Default Technical support
My 2004 cross-fire won't crank please what are the solution to the problem please I really need help here please
Old Jun 1, 2020 | 02:34 PM
Default Re: Technical support
check the batt make sure it is FULLY charged
disconnect the batt for 10 to 15 min. retry
try another rcm or send it to tighed1 for repair https://www.crossfireforum.org/forum...-no-start.html
is it trunning over and will not start,,
Old Jun 1, 2020 | 03:06 PM
Ifecollins's Avatar
I have changed the rcm still same thing I also removed the battery head for 24 hours please sir any other solution?
Old Jun 1, 2020 | 05:16 PM
Do the lights on your dash come on when you turn the key? Does it make any sound ?
Old Jun 1, 2020 | 05:27 PM
Ifecollins's Avatar
yes the ignition light on dash always comes on when I turn it on and it makes some beep sound but if I start the car it won't crank. I don't know if it's an error with the key chips transponder
Old Jun 2, 2020 | 08:56 AM
zip439's Avatar
You say you replaced the RCM. With what? Is it brand new, What brand and part number?
Have you read this? What about the relays they are problematic at the age of our cars.
What did you do with the RCM you removed from the car? If you still have it, send it to tighed1 for repairs. He will not only solder it correctly, but will inspect and replace any relays that have gone bad. When you get it back slide it back into the correct spot in the black plastic box and try starting your car again.
Even if you have a brand new Mercedes RCM installed you may have a problem with the electrical connector, read this: CLICK
There are other possibilities as to why your car won't start, but you must first be absolutely certain you have eliminated the RCM as being the source of your problem.
PS do not start messing with the FOB. You will only introduce more problems. You could remove fuse #9 in the under hood fuse box and try to start the car with that fuse removed.
tealcamaro55
Oct 31, 2023 09:04 PM
Punkin
Jan 16, 2009 07:23 PM
craftomatic
Apr 11, 2008 02:30 PM
Jeff Cobb
Oct 21, 2007 11:52 AM
ChrisG
May 11, 2004 09:34 AM
