convertible
Old Aug 25, 2020 | 10:23 AM
kernol2's Avatar
Default convertible
So, I have two concerns. First my switch for my convertible top fell through the console. This has happened before and I "jury rigged" it, again. I need to get a replacement console in dark gray if anyone has one to sell.
My second concern, my convertible top stuttered to go down and stopped 1/2 way down. I saw the video on how to manually lower the top, I did do that. Now when I press the button (after I removed the console, the windows go down, but that is all that happens. I checked sensor number 5 and it is good. I am not sure where to go from here. The sensors in the back of the trunk are fine, So, I am thinking it is something to do with the convertible top sensor, or the arms that lift the top.
I appreciate any thoughts anyone may have.
Cathy
Old Aug 25, 2020 | 11:10 AM
Default Re: convertible
Have you checked the fluid level in the pump?
Old Aug 25, 2020 | 09:03 PM
dcskmail's Avatar
I would lube all of the hinges/pivot points on the frame, it will reduce the stress on the pneumatic system . Just a thought but the harder you push a button will not make any difference. It will not go faster if something is broke pushing the button hard will not fix it. this applies to all of our controls it is a natural reaction. No offense intended
Old Aug 25, 2020 | 09:32 PM
A lot of current info regarding our convertible tops has recently been posted by Pizzaguy
CLICK>>>Convertible Top Sensors
Old Aug 26, 2020 | 04:30 AM
Viper-666's Avatar
Cathy
I have glued mine back on place with hotglue works fine.
Old Aug 26, 2020 | 12:40 PM
Shamrock's Avatar
Sent you a pvt msg
Old Aug 26, 2020 | 12:41 PM
Shamrock's Avatar
Check your msgs
Old Sep 1, 2020 | 05:23 PM
kernol2's Avatar
What did you glue it to? The plastic piece that held the switch broke off completely.
Old Sep 1, 2020 | 05:28 PM
kernol2's Avatar
Thank you, I will check the fluid.
Old Sep 1, 2020 | 05:29 PM
kernol2's Avatar
None taken! Thank you.
Cathy
Old Sep 2, 2020 | 07:02 AM
Viper-666's Avatar
I glued the whole switch from the underside of the cover in the cover. But use hotglue, so you have a change to get it out if you want.
CCrossfire
Apr 29, 2004 07:16 PM
imported_mightyjlr
Apr 27, 2004 12:16 PM
crossfiretech
Jan 20, 2004 10:00 PM
macjake
Jan 19, 2004 03:48 PM
macjake
Dec 1, 2003 01:05 PM
