Anyone know what this is?
Old Nov 18, 2024 | 06:24 AM
Bensley's Avatar
Default Anyone know what this is?
2006 crossfire limited. Does anyone know what this is and if it should be plugged in somewhere please?
Old Nov 18, 2024 | 10:44 AM
zip439's Avatar
Default Re: Anyone know what this is?
IF, that is what I think it is:
That is turned up. It normally is turned down. It connects near the EGR valve electrical connector by a small vacuum line about 3 inches long. It may be missing a rubber covering as mine appears larger and rubber when view from the top, it's normal position. It does not appear to attach to anything at the end you are seeing (normally the down pointing end). I'm guessing it is a filter or check valve.
Old Nov 18, 2024 | 03:44 PM
Bensley's Avatar
Thank. It is pointing up as I positioned it this way for the photo. I was worried it was supposed to be connected to something
Big Daddy
Canada
Jun 30, 2017 10:18 PM
Big Daddy
Canada
Jun 19, 2017 04:19 PM
AlbertFattal
May 24, 2012 12:13 PM
James1549
Northeast Forum
Jul 31, 2009 10:50 PM
HDDP
Racing
Jan 28, 2007 03:57 PM
