Pitted Headlight Fix Diy
Old Mar 12, 2008 | 08:31 PM
cgocifer's Avatar
Default Pitted Headlight Fix Diy
For anyone brave enough:
http://www.nseconsulting.com/bmw/hpt.pdf
Old Mar 12, 2008 | 09:16 PM
Mike-in-Orange's Avatar
Default Re: Pitted Headlight Fix Diy
Yep, that's definitely the best way to do it. I've done it on a couple of cars but it does help to be reasonably proficient with a rotary buffer - using one improperly leads to really bad results.
Old Mar 13, 2008 | 08:53 AM
blue pearl's Avatar
I have done this to my 95 Talon. I kept the sandpaper wet at all times and used 'silver' polish for the final step. I did it all by hand because of the curve in the lens, it went well.
Old Mar 13, 2008 | 02:46 PM
patpur's Avatar
Senior Member/Moderator
Its safer if you use an orange cutting pad, a Porter Cable polisher and some plastic cleaner, I use both 3M and McGuiars. You can also use either company's scratch remover. I finish it off with the pink Zaino 2 polish. I've never had to use the sandpaper and it takes all of 5 minutes with the PC. I had both the haze and etching and my headlights look better than new. One thing I've noticed. After washing your car dry off the lenses quickly. I think there is a chemical in the water supply that causes the etching. I blow dry my car with a leaf blower and then towel dry whatever is left. I started doing this to cut down on the number of towels I was using to dry my car. I went from 4 or 5 to 1. And yes use only a 100% cotton towel or micro fiber towel.
Pat
Old Mar 13, 2008 | 04:35 PM
stevieb's Avatar
another sticky me thinks..
Old Mar 21, 2008 | 09:41 AM
GDrag's Avatar
I've done it. It's a sticky on the "Detailed section" section of the forums. Did it on my very own crossfire for those of you wondering if it would turn out the same.
rampntlion
21
Feb 11, 2019 08:18 AM
onehundred80
Aug 6, 2016 12:03 PM
Franc Rauscher
May 9, 2016 12:04 PM
UNDER PSI
Nov 1, 2015 09:39 PM
RacerXofFL
Sep 15, 2015 05:00 PM
