looking for a part
Old Jun 26, 2008 | 02:32 PM
meandangie's Avatar
Default looking for a part
came outside the other day to a flat tire. i used the bottle and plug in generator to fill it up. noticied that the bottle with the "fix a flat" stuff is empty. can anyone please tell me where i can get a replacement bottle at. i have searched all over online and cant find. thnx
Old Jun 26, 2008 | 04:01 PM
Alabaster04's Avatar
Default Re: looking for a part
Not sure where to get the OEM part, try your local "Stealership" but here is a link that has "Slime" replacement products that do the same thing. Just scroll down the page a bit and you'll see them.
http://www.jcwhitney.com/Chrysler-Cr...-600018042.jcw
Old Jun 26, 2008 | 05:10 PM
imabenz's Avatar
You should really avoid the fix-a-flat stuff whenever possible. Fellow forum members have reported that it ruins your tire. The goo basically renders the tire un-repairable.
You will be better served with a good tire plug repair kit.
I guess in an emergency, the goo will save the day, but you may need to buy a new tire to replace an otherwise repairable tire.
Old Jun 27, 2008 | 04:45 AM
spensley's Avatar
Any autoparts store will stock it.
Old Jun 27, 2008 | 10:30 PM
70GT6's Avatar
From slime.com, regarding tire and TPMS:
Currently, there are two types of TPMS devices available: Direct and Indirect. SLiME Tire Sealant’s TPMS formulation is compatible with all TPMS systems. However, it is important to note that once installed, Slime Tire Sealant may come in contact with the sensor in a way that renders the sensor TEMPORARILY inoperable until it is properly cleaned, inspected and re-installed by a tire care professional.
Because SLiME is a water soluble flat repair treatment, it is easily removed from the tire with water. At the time the affected tire is inspected by a tire care professional, they should clean the sealant from the tire, prepare the area and repair with a Rubber Manufacturer’s Association (RMA) approved patch/plug. The TPMS device should also be cleaned off with water to remove any sealant which may have come into contact with the device. Do not use any fine objects to ream and clean the small pressure sensor opening as it may damage the electronics. After the repaired tire is replaced and inflated the TPMS system will resume operating as normal.
xfClifford
Sep 6, 2015 08:20 PM
Mackel
Aug 28, 2015 06:11 PM
Helot
Aug 15, 2015 04:19 PM
55chevy
Jul 27, 2015 08:02 PM
SuperD500
Jul 23, 2015 02:53 PM
