Secondairy air pump code...need help
Old Jan 26, 2009 | 10:33 PM
Cesdog26's Avatar
Default Secondairy air pump code...need help
A code poped up and is from my air pump relay curcit malfunction. Has this happen to any of you guys. And if so, did you get it fixed?
Old Jan 26, 2009 | 10:37 PM
Cesdog26's Avatar
Wink Re: Secondairy air pump code..need help
A code poped up and is from my air pump relay curcit malfunction. Has this happen to any of you guys. And if so, did you get it fixed?[/quote]
Old Feb 23, 2009 | 01:18 PM
jorge garcia's Avatar
Default Re: Secondairy air pump code..need help
co de p0410 check engine light comes and go what seens to be tue problem?
Old Feb 23, 2009 | 08:54 PM
Cesdog26's Avatar
Default Re: Secondairy air pump code...need help
Secondariy Air Pump Relay Short To+??????? What Do I Need To Buy To Fix This. Im A Very Good Tec And Cant Fix This.
Old Mar 6, 2009 | 10:17 AM
ryan48's Avatar
i replaced the pump w a low mileage used one from a guy on here who had some, no problems since...they are known to go bad
Old Mar 6, 2009 | 04:15 PM
aschrager's Avatar
Default Re: Secondary air pump code...need help
On mine the dealer changed the relay module. The Chrysler tech rep said it is a common problem. ( all was done under warranty )
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
cppeabody
Sep 15, 2015 08:43 AM
81's
Sep 13, 2015 04:34 PM
crmnal
Sep 6, 2015 08:07 AM
