How to replace that pesky broken ashtray/coin holder
Old Aug 13, 2011 | 09:19 PM
killerkanadian's Avatar
Default Re: How to replace that pesky broken ashtray/coin holder
Walmart sells them, I think Advance Auto does as well.
I got mine at WalMart for about $4. They dont' say "Crossfire" on them and don't ask for "Crossfire" ... anything. You'll only get a blank stare.
Most people here in kansas don't even know what a crossfire is off the top of their heads.
Old Aug 13, 2011 | 09:22 PM
Any tips where to look for a new ash tray besides a junk yard? Or anything cool to put in it's spot? I'm about to tape mine shut for the mean time...
Either that or open it up and take the spring out or something...
Old Aug 15, 2011 | 03:00 AM
Mimi05SRT6's Avatar
My coin holder also doesn't lock into place. I use a couple of nickels together and squeeze it in between to keep it shut. Of course I'm always using the coin holder because of the friggin' tolls in Orlando.
Old Aug 15, 2011 | 07:29 AM
THat's the worst idea i've ever heard. I'm going to try this later today lol.
Old Sep 3, 2011 | 08:38 PM
Is #3 what i would need?
https://www.moparpart.com/partlocato...layCatalogid=0
Old Sep 3, 2011 | 09:34 PM
AlbertFattal's Avatar
I put double sided scotch tape around a quarter, and wedged it inbetween the coinholder and dash around to keep it closed, similar to the nickel treatment
Old Sep 4, 2011 | 08:51 AM
A quarter? That is a cheap fix, any way it can be done with a nickel?
Old Jul 19, 2012 | 07:14 PM
totoferny's Avatar
Guys I am trying to get to my ashtray. I have slid our my JVC aftermarket radio but I can't seem to get the large dash bezel surrounfing it to come off. I don't want to force and break it. Does anyone know how I can remove the radio and A/C contreol Dash panel off?
Old Jul 27, 2012 | 02:44 PM
a7x6kse6's Avatar
There are two screens in the upper corners of the radio slot.
Old Jul 27, 2012 | 05:17 PM
That should be two screws.
Old Jul 28, 2012 | 10:46 AM
totoferny's Avatar
Got it, good deal, I missed those the first time. My aftermarket radio install harness didn't give me much space to pull out completely and I didn't want to cut any wires so I had a terrible time trying to take out the ash tray to survey the problem and find a solution for it staying open. I ended up removing the mechanism lid on top of the ashtray and releasing the spring strap from its forward facing connection. Problem solved. My ashtray now closes. It doesn't do the nifty push and auto open like it did but since I don't smoke I seldom use it to maybe put keys or flash drives for music so I'm okay with it.
Thanks guys!
Old Aug 13, 2013 | 12:26 AM
milky's Avatar
Hey everyone, I'm trying to fix my ashtray that won't stay closed. And every other thread directs me here, and the info is great. But, as far as I know the Photobucket images have been deleted, Anyone know if they can be found anywhere else?
Old Aug 14, 2013 | 12:18 AM
philosophico's Avatar
Funny, my ashtray is the opposite. It wont open, it doesnt slide open when pushed on, I have to pry it out some and pull it out. Either way, it mainly stays shut just another reminider of the poor built items inside this car, that and the cup holder.
Old Sep 7, 2013 | 04:46 PM
rabatts's Avatar
To get the ashtray to stay in...(I'm not proud of this fix but it works) I put a piece of black spongy rubber on top of the tray and pushed it in. The rubber holds it in place and you can still pull the tray out if you need to. Also, the rubber is not visible when the tray is closed and when you pull the tray out, the rubber falls into the ashtray ready to use again. I am hoping for a fix to make it work like new again without taking the dash apart.
Old Oct 6, 2013 | 10:03 PM
Cedar11's Avatar
I have the same problem, anyone have any pictures that might be helpful?
Thanks in advance.
Old Oct 8, 2013 | 03:35 PM
rabatts's Avatar
I have updated my original post in include pictures
rabatts
Old Jan 21, 2014 | 06:34 PM
B1gfun's Avatar
rabatts
I went to the first post and was unable to open the pics. Any help?
Old Jan 22, 2014 | 03:07 PM
  #38 (permalink)
B1gfun's Avatar
Originally Posted by chevyboyac
This is fairly easy all you need is a crosstip screwdriver, radio removal tools...you can get these from walmart for 4.50$ and a upholstry removal tool OR a knife if you are careful! otherwise you will scratch the console. I am attaching a link to a photobucket picture because I cant get the picture to load on here ...shocker.....anyway if you look at the picture its fairly straight forward ...the key is paitence and be gentle prying. First pry up #1 in the pic....its the shifter surrounding....next pry up the shroud thingy inside the first shroud(#2 in the pic)....look at the pic you will know what I mean. Then pry up (#3) the biggest shroud around the shifter. These should come up easy just dont pry hard and work your way around the shifter and it will come up. Next insert the radio removal keys into the radio (you can see them in the pic) and if correctly inserted the radio will slide right out. And finally unscrew the 4 screws that hold the ashtray in, you will have to undo a few wires once you get it out. Its a tight fit ( I mean the ashtray in that small hole. You will need to push it towards the driver side then angle that pass, side towards the rear off the car and rotate it out...........then just reverse these steps putting it back in.......I used a manual and it said I had to remove all kinds of other junk ...as you can see in the picture....you dont need to do that and its a complete waste of time if you do. Anyway I hope this helps, its my first how to type of post and Its prolly really crummy of a post but eh oh well :P PM me if you have any questions. Thanks
VVVVVV PIC VVVVVV
DSC01178.jpg picture by chevyboyac - Photobucket
Im looking for the photobucket images . Anyone? Rabbatts has the weather stripping fix pics, but I would like to take it out and try to fix.
Old Jun 12, 2014 | 10:05 AM
  #39 (permalink)
ttfo's Avatar
I am new to the forum. Where do I find the pictures?
Thanks
Old May 24, 2017 | 02:30 PM
  #40 (permalink)
bucketlisted's Avatar
You mean this picture?
Just copy the link at the bottom of the four listed (starts with [IMG}http... ) on the left of your photo bucket page and paste into this thread.
Good picture and a good write up, making yourself useful is good for all on this forum.
Great.
Edit your thread, add the picture and change the words and I will erase this picture.
180,
can you tell me where i can find this photo?
i have searched everywhere ?
thanks
