Power Locks Need Help Asap
Old Feb 4, 2010 | 12:20 PM
murtazanooruddin's Avatar
Red face Power Locks Need Help Asap
i have a 05 crossfire my power locks stop working. when i press lock or unlock on remote the flashers flash but locks dont open or lock tried using switch on dash no luck with that either. i have checked fuses inside the fuse box for central lock all fuses are good... i park my car outside and i need to have it locked please any help would be greatful
thanks in advance
Old Feb 4, 2010 | 01:31 PM
hcarter's Avatar
Default Re: Power Locks Need Help Asap
You might want to change battery in key fob that may help Good luck
Old Feb 4, 2010 | 01:34 PM
well i tried that also no good same as before the flashers blink but no locks actully open even the switch from inside doesnt work
Old Feb 4, 2010 | 01:48 PM
billvp's Avatar
I have no idea about the locks (btw, my '06 Chrysler minivan just started doing this also, although it is an aftermarket system), but you can lock it with the key anyway can't you? That'll at least leave it safe in the parking lot.
Old Feb 4, 2010 | 02:11 PM
I believe the lock are pneumatic, air pressure. You might have an air leak or blocked hose.
Old Feb 4, 2010 | 02:12 PM
thanks in advance
My guess is that the air/vacuum pump located in the trunk, which operates these locks, is broken or the air/vacuum line is broken somewhere.
Can you hear any noise of air in the trunk. If one lock was not working I would say that one air line to that lock was broken but if no locks operate I would guess it is the pump or a main air line from that pump that is causing the trouble.
I am assuming that the locks for both doors and the rear hatch do not work .
Old Feb 4, 2010 | 02:15 PM
Repair manual PDF
http://www.gleamingedge.com/mirrors/...e%20Manual.pdf
Old Feb 4, 2010 | 03:05 PM
Hawk Monster's Avatar
180 that is absolutely correct. There are three modules back there. If I remember correctly, it is on the right side as you look into the truck. Price may be pricey but is a simple remove and replace. If I also remember it reads the VIN to work correctly.
Old Feb 4, 2010 | 03:38 PM
lesr's Avatar
The one other thing that you may look at is the
Sentry Key Remote Entry Module (SKREEM) It is
located underneath the top pad of the instrument panel
behind the Instrument Cluster. The SKREEM works in conjunction
with the vehicle locking/unlocking remote control and the
Central Locking Pump/Security System Module to lock and
unlock the vehicle.
Old Feb 4, 2010 | 10:39 PM
patpur's Avatar
Senior Member/Moderator
Does your deck lid lock?
How about your gas filler door?
If all those work then chances are its a leak somewhere in the front of the car. If none of your locks work the pump either has a major leak or its shot.
I had a similar issue with my deck lid and gas filler door and it was one of the pneumatic lines. I had the dealer fix it because I didn't feel like tearing the interior apart. If there is a leak you should be able to hear it. Hit the lock and you should hear a hissing sound. I think 180 is right on the money, I concur with his assessment of the problem. Let us know how you make out.
Old Feb 4, 2010 | 10:57 PM
tighed1's Avatar
A Johnson Pump oughta fix that right up.
If not it's probably the vacuum pump located in the trunk.
Old Feb 28, 2010 | 06:01 PM
Exclamation Re: Power Locks Need Help Asap
how much does the whole Central Locking Pump/Security System Module cost i pulled out the whole box and there was water inside there all over the circuit board and the pump so im thinking the whole thing mighty have been out. any suggestions?
Old Feb 28, 2010 | 07:36 PM
I have no idea of cost but these are supposed to be the part numbers.
The Mercedes part should be cheapest.
(numbers from the forum master parts list)
Central Locking Pump module for a Chrysler Crossfire 2004 -2008
or Mercedes Benz SLK 2004 - 2008.
The Chrysler part number is 05102774AA
The Mercedes Benz part number is 17080000848.
Old Mar 1, 2010 | 12:16 AM
tighed1's Avatar
I'd find out how water got in there before I replaced it.
Don't wanta fry a new one.
Old Mar 1, 2010 | 04:04 AM
I can't say how the water got in for sure, but in a similar post the poster said the drain in that area was plugged, but I have never seen in that area.
I believe the water came in from the wheel well area where the domed area meets the flat area..
Old Mar 2, 2010 | 12:49 AM
Smile Re: Power Locks Need Help Asap
ok heres an update i replaced the the central locking vaccum pump/module got one at an old junkyard off an 04 xfire.....installed and then tried didnt work. so with that still in place i decided to look at the relays up in the fuse box under the hood there are two 1 is yellow and 1 is black one being for the remote and other for the module..those are fried ny one knwo where i could get those? if at dealer approx how much they would cost it be greatly appreciated
thanks
Old Mar 2, 2010 | 08:38 AM
thanks
I take it that the junkyard has not got them, so try another scrap car dealer, a Merc part is also a good bet.
Old Mar 2, 2010 | 04:10 PM
thanks guys for all your help found relays at another junk yard replaced both the yellow and the black...all the locks and blinkers work properly.
Thanks
Old Mar 2, 2010 | 04:13 PM
Just curious, how did everything get so wet?
Old Mar 2, 2010 | 04:15 PM
well i had a 5 gallon water tank, and it broke in the trunk so water got all the way down there....but it was weird cause even after that it worked for a month then it stopped. o well now it works
