Car dies
Old May 23, 2011 | 11:11 PM
ivo 1's Avatar
Default Car dies
Need your help. My car starts.,idles and 15 seconds later dies. Car was fine but this morning., no go. Gas pump? Just changed the gas filter., complete tune up. Any ideas?
Old May 24, 2011 | 07:01 AM
mdaniels4's Avatar
Default Re: Car dies
probably the crank sensor or the controle module
Old May 31, 2011 | 10:31 PM
ivo 1's Avatar
Thanks mate., but no go its a 04 limited
Old May 31, 2011 | 10:53 PM
tighed1's Avatar
04's didn't have crank sensor or relay control module?????????????
Sure it's a Crossfire?
Old Jun 1, 2011 | 04:54 PM
'04.....I'm missing something here....Crankshaft Position Sensor, or the Relay Control Module is what they are suggesting is wrong with your car....if it is a Crossfire....lol.....if not, wrong forum.....
Old Jun 1, 2011 | 06:55 PM
If you have pissed someone off or have some pranksters around you could have two potato's shoved up your exhaust pipe.
Old Jun 2, 2011 | 12:41 AM
ivo 1's Avatar
HaHa. Ya checked on the Patatos but no. Well its a 2004 crossfire limited. Its not the crankshaft sensor. Or it would not turn over. Ganna do a fuel pressure test tomorrow. think i have a few new white hairs...
Old Jun 2, 2011 | 07:54 AM
chisler29's Avatar
Mine is a 2004 and my CPS went out. car would turn over, just didnt start. ran the code said it was the CPS, took it to the dealer, they said it was the CPS, replaced it and car runs fine. So the car will turn over even if the CPS is bad.
Old Jun 2, 2011 | 08:13 AM
Have you thought of putting the old fuel filter back on and trying it?
It is not just a filter as there is a pressure regulator in it as well and that may have failed.
I always believe in trying the simple things first. It may be just a coincidence that you have a problem now but ......
Why did you change the filter, mileage or problems?
Old Jun 2, 2011 | 08:43 AM
tighed1's Avatar
You need to spend more time on the forum!
All of us "regulars" know that the car WILL crank with a bad CPS.
Check out this thread for more on the CPS problem.
THREAD
mhajek18
Dec 30, 2015 03:40 PM
ultrajim49
17
Jun 27, 2015 12:20 AM
mhajek18
Jun 17, 2015 01:35 PM
gobraves423
Jun 6, 2015 07:03 PM
MARK_UK
Aug 3, 2003 06:29 PM
