Getting scratches out of headlights...hard to see.
Old Aug 1, 2011 | 12:35 AM
austinboyette's Avatar
Question Getting scratches out of headlights...hard to see.
Ok, so my headlights have alot of scratches in them from the previous owner. I installed 10,000K HIDS in my Lo's and Fog's, Ive tried sanding with 1000G sandpaper and 2000G sandpaper then using meguirs resotoration kit and it still didnt work, I really need some help.. Thanks!!!
Old Aug 3, 2011 | 10:19 PM
magneticred's Avatar
Default Re: Getting scratches out of headlights...hard to see.
I have not personally tried this, but this write-up looked interesting and might help:
Headlight Restoration-new UV sealant idea - Auto Geek Online Auto Detailing Forum
Old Aug 3, 2011 | 11:43 PM
Joliet John's Avatar
I'll go as low as 600 grit on really bad headlights. I also use a 3" sander. The key is, whatever grit you start with, you have to get everything done with that or you're just going to have to start again. The best way to tell is to have a spray bottle and wet the headlight as you are sanding, so you can see if you got everything.
Then I move up in grit by 200's - 600, 800, 1000 ... from there I go to 1500 then 2000. All you're doing there is getting out the sand scratches from the previous grit.
Then I use a extra cut compound on a wool pad (3" again), buff it clear and smooth, then I use a finishing compound on a black foam pad.
Old Aug 3, 2011 | 11:51 PM
JHM2K's Avatar
^^^This
Old Aug 4, 2011 | 07:35 AM
maxcichon's Avatar
I'm surprised no one has pointed this out yet:
With 10000K (Purple/Violet) HID's, you won't be able to see anything, anyhow.
Read:
Daniel Stern Lighting Consultancy and Supply
xfireohio
Jul 20, 2020 12:03 AM
2005 Ragtop
Apr 25, 2016 05:09 PM
rdougc
Sep 5, 2015 10:30 PM
Abaton6
Aug 16, 2015 12:55 PM
PHeez
Aug 11, 2015 01:30 PM
