Head gasket scheme ...
Old Nov 28, 2013 | 04:26 AM
simkard's Avatar
Question Head gasket scheme ...
Hello everybody !
I'm actually in some kind of a project where i will compress the N/A 3.2 M112 of my Crossfire.
I need to make up a laser-cut on some metalic part to space the engine-head from the engine itself.
This is for lowering the compression ratio of the engine and in order to allow more boost to come from the intake.
By doing this, i will not break the engine, nor connecting rods, nor nothing at all ... except, perhaps the transmission/rear differential
But that is another story.
For now, i need to build up a scheme in order to give this scheme to the laser-cutting Professional i will be working on.
So my question is simple : do you know some kind of scheme like this /OR/ do you know any personnal that works @ mercedes and could give me this kind of document ?
Thanks !
Old Nov 28, 2013 | 08:10 AM
Default Re: Head gasket scheme ...
Spend $25 and get a set of new gaskets from RockAuto for a 2003 SL320 as a pattern ......
( are YOU doing the turbo ? )
Old Nov 28, 2013 | 12:02 PM
+fireamx's Avatar
Why not just "double up" head gaskets?
Old Nov 29, 2013 | 03:12 AM
simkard's Avatar
I wanted to do this method, but it seems that it is really more expensive than having directly the template.
At least if i have to reproduce it from PDF to AUTOCAD, there is no problem for me, i'll do it, for sure.
Old Nov 29, 2013 | 03:14 AM
simkard's Avatar
What do you mean with "Double up head gaskets" ?
Is it adding 2 head gaskets instead of 1 ?
If yes, i'll answer that it is not enough to lower the compression ratio to what i want.
Adding another head gasket would only lower the CR from 10:1 to 9,7:1 at best.
Actually, as i'm going to run 1bar of additional BOOST, i will have to lower the CR to 8.5:1 or 8:1 at best.
Old Nov 29, 2013 | 07:36 AM
What is to be the source of the "1bar" boost ?
Supercharger or turbocharger ?
fastfred
Nov 5, 2018 09:47 AM
minimayhem
16
Aug 23, 2016 07:47 AM
o55ie18
Oct 5, 2015 05:50 PM
crossfireE
Oct 2, 2015 01:40 AM
RacerXofFL
Sep 15, 2015 05:00 PM
