HowTune Crossfire How to articles
Old May 26, 2016 | 02:49 PM
Default HowTune Crossfire How to articles
Twelve how to articles for the Crossfire by HowTunes.
A great site originally found by BisB with great info on other cars as well.
Click on the article that you need.
Change the Oil
Replace the Coolant
Replace the Headlight Bulbs
Disable the Tire Pressure Warning Light
Replace the Crankshaft Position Sensor
Replace a Brake Light Bulb
Bleed the Brake Fluid
Bleed the Clutch
Replace the Steering Stabilizer
Replace the Front Brake Pad
Replace the Rear Shocks
Replace the Cabin Air Filter
Old May 26, 2016 | 06:55 PM
Steve Jr's Avatar
Default Re: HowTune Crossfire How to articles
Thank you again 180, for sharing a good option. It will be great, to point new members and novice DIYer's to a place where they can learn how to maintain their cars. I read a couple and they are clear, straight forward and simple. Good tool ,for added help.
And you also, BisB
Old May 26, 2016 | 08:03 PM
Except for the one where the guy is handling the headlight bulb with his bare fingers, and no warning about it.
There I go again, glass half full.
Anyway, Thanks 180 !!!!!
Old May 26, 2016 | 09:39 PM
I just used the site BisB found, used that sites search function to look for more Crossfire articles and came up with these articles.
The bulb he is holding looks old and a little rusty, the warning is missing though.
I redid the first post, it is a good site, with clear articles.
Old May 27, 2016 | 05:46 PM
Bump, rewritten post #1 (CLICK).
Old May 27, 2016 | 06:51 PM
I think a lot of that info originated right here on this site. You think?
