Getting to blower control switch Back
Old Jun 11, 2017 | 10:05 AM
cobra1951f's Avatar
Default Getting to blower control switch Back
Hoping STICKY see's this post as he seems to be the MAN on a lot of post on the crossfire, I need to get to the back of the control panel for the blower switch to check the connections, it was working then quit after putting a bomb off in car for bugs!! I don' t want to break any o the parts but think the spray got on the connections??
Old Jun 11, 2017 | 10:24 AM
Default Re: Getting to blower control switch Back
You have to remove the radio, there are 2 screws in there for the panel.
Old Jun 12, 2017 | 07:44 AM
cobra1951f's Avatar
How does the edging around the console area of the radio ac/radio come off to get to the screws, as I think I need to remove that 1st to get to see anything? including the radio, I think i got the link you sent and thanks
Old Jun 12, 2017 | 07:59 AM
cobra1951f's Avatar
still working on it
Old Jun 12, 2017 | 09:47 AM
The radio is removed by using the 2 removal keys in the two vertical slots in the faceplate.
You can pick up a set of universal keys at Walmart.
Old Jun 12, 2017 | 01:37 PM
The slots are horizontal by the way.
Remove the radio and unplug it.
Undo the two screws that are now just visible where the top front edge of the radio was. You should then be able to use a trim tool to carefully pry the bezel off starting at the top corners.
I'll add a couple of pictures to give you an idea.
Old Jun 12, 2017 | 01:59 PM
Horizontal you say !!!
Gee you are right. Maybe that's why I haven't been sleeping too well lately.
I have the two confused
Old Jun 12, 2017 | 02:13 PM
I heard you slept hanging upside down from the rafters, so that fits.
Old Jun 12, 2017 | 03:52 PM
cobra1951f's Avatar
thanks that will work out perfect I figured there must be something special
Old Jun 12, 2017 | 04:50 PM
As Dave ( onehundred80 ) pointed out, those are horizontal, not vertical slots.
