Cigarette lighter socket repair
Old Jul 21, 2017 | 04:04 PM
Default Cigarette lighter socket repair
Constant use of the cigarette lighter socket as a power outlet for a Garmin GPS unit and cell phone charger caused the two little spring retainers in the socket to get bent and not hold the depressed lighter in place while it warmed up.
The adapters on these two cables are wobbly and bend the springs out of position.
With the ignition off and using a small screwdriver I bent the springs back into position.
Not that I use the lighter but I like things to work properly.
Old Sep 11, 2017 | 03:16 AM
dylan07's Avatar
Default Re: Cigarette lighter socket repair
Perhaps you should have combined this with the "tips for double din install" thread. Because the dash has to be taken apart for both cases.
Old Sep 11, 2017 | 07:22 AM
No it does not, you just work down the hole the lighter goes into.
Old Sep 11, 2017 | 07:27 AM
This was a good heads up for others of us. Thanks.
Old Sep 11, 2017 | 07:34 AM
So I gather by your post, power to the cigarette lighter occurs when the ignition switch is turned on (which is a good thing). Back when I owned Merkur XR4Ti's, the cigarette lighters (1 up front; 1 mounted in rear of console for backseaters) were hot-wired to the battery. The one in the console's rear was bad about malfunctioning (geometry between socket & lighter in rest position) and could come on & stay hot. One of my XR's had a battery drain issue which I traced to the rear cigarette lighter socket.
