Screen Demister not Working
Old Oct 13, 2010 | 01:48 AM
UK ken's Avatar
Unhappy Screen Demister not Working
Unable to direct air to windscreen vents...Remainder are working correctly with hot or cold air.
Any thoughts regarding this problem?..before I remove the dash..which I'm dreading...but with the main dealer at Soutampton charging a staggering £110.oo per hour!!!!..I have no option.
Steamed-up UKKen.&
Old Oct 13, 2010 | 02:59 AM
GDC-SRT's Avatar
Default Re: Screen Demister not Working
Hope this is what you are looking for.
Look at post #15 in this thread.
https://www.crossfireforum.org/forum...-describe.html
Old Oct 13, 2010 | 04:29 AM
UK ken's Avatar
Thanks for info ..will chech it out.
UKKen.
Old Oct 13, 2010 | 02:21 PM
xfchris's Avatar
ken might like to check the vacuum pipes on the switch valve as stated in previous post, i had a cherokee that had this very problem, fortunatly was still in warrenty but was found to be a pipe had somehow detatched itself from the valve, if its easy to get to might be worth checking this out first before you tear your dash apart....
Old Oct 25, 2010 | 03:21 AM
UK ken's Avatar
I'm about to remove the trim form under the dash..passanger side and the inside panel, plus the glove box..
Before I do? How can I switch off the airbag? as i don't want to set it off while poking around under the dash....any thoughts?
UKKen.
Old Oct 25, 2010 | 01:41 PM
Steve - UK's Avatar
UKKen.
Ken
I believe there may be info about airbag de activation in owners handbook. Sounds you have a job on your hands there - is the car under any warranty?
Old Oct 25, 2010 | 08:45 PM
UK ken's Avatar
Ken
Thanks Steve..Warrenty,yes, but not one I can afford to use with a preset low hourly rate of £55.00 per hour,(RAC policy included with purchase) and the main dealers rate is £110..so you ses the problem I have, as I have to make up the shortfall. ..so will try and locate fault myself and hopefully fix it.
Hope your oil free now?
UKKen
Old Oct 26, 2010 | 02:52 AM
The bodyman's Avatar
Hi Ken.
Have you fixed it yet? If not and I know we are miles away, but if you are around this way at some stage, I could get one of guys to take a look.
Good luck
Jon
Old Oct 26, 2010 | 09:17 AM
UK ken's Avatar
Originally Posted by The bodyman
Hi Ken.
Good luck
Jon
Jon..What a really kind offer. I will have a mini poke about and if no luck...will give you a call.
Thanks again
UKKen.
pioneer4x4
Sep 18, 2023 11:49 AM
PNA
Nov 12, 2020 04:44 PM
PimpDaddy
Sep 29, 2016 11:55 PM
mopar1969
Aug 6, 2016 02:21 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
