Tyre pressure
Old Nov 21, 2010 | 11:12 AM
Rowanbud's Avatar
Question Tyre pressure
Hello! Just a quick question about tyre pressures. I checked my air today - been very lax and not done it for over 4 or 5 weeks now (I know I know!!) and the pressure in the rear tyres had dropped to 29 in each. Is it usual for the tyres to lose air pressure like this or have I got a problem??? I've had cars that do tend to lose pressure if not checked and some that don't so I'm not sure what to think (apart from I must check far more reguarly!) Thanks in advance for any advice.
Old Nov 21, 2010 | 01:18 PM
muskrat's Avatar
Default Re: Tyre pressure
Probably just natural loss and its quite a bit colder than it was 5 weeks ago - its only 3 pounds.
Old Nov 21, 2010 | 04:15 PM
Rowanbud's Avatar
Good point about the weather. I worry too much, I know lol!
Old Nov 21, 2010 | 05:03 PM
Steve - UK's Avatar
Must admit I only check them every few months and they usually need a pound or two, I run them at 32 rear and 31 front. The ride can feel a bit hard sometimes!
Old Nov 21, 2010 | 10:17 PM
itsky's Avatar
Living in a colder environment myself, tire pressure can easily drop. During this time of year with the cooler weather, all my cars start to show low tire pressure light. I don't think any tire is leak-proof, so some air lose is natural.
Old Oct 10, 2013 | 10:07 AM
dibri1's Avatar
Just had my Crossfire serviced & MOTd at Mid Kent Chrysler....excellent service if you ever need a garage.
Checked my tyres this week & was amazed to see they had put 36 psi in them. Like Steve, I usually run on 31-32psi. Mid Kent Chrysler says they use the official manuals & they recommend 36 psi.
Tyre & ride feel ok, but I'm dubious about having them this high in the winter in snow/ice. The car isn't great in icy conditions as we know, so what psi does everyone else run their tryes at?
Confused!
Old Oct 10, 2013 | 10:17 AM
32 rear, 31 front
Old Oct 10, 2013 | 10:37 AM
When the light comes on and the air is colder around the car you can bet that the light was very close to coming on anyway. These tires do not have much volume inside so a loss of a few cubic inches of compressed air will have have more effect than the same loss of air in a larger tire at the same pressure which has more volume inside it. This is quite obvious when you note the time it takes to use the air hose on our tires to raise them one psi as compared to the time a larger tire takes to get the same one psi rise in pressure.
Driving the car may turn the light out as the air in the tire warms up but it is still requiring more air to get the tire to the correct pressure and a better wear rate.
Old Oct 10, 2013 | 12:53 PM
UK-SRT6's Avatar
UK pressures, N/A 33 rear 32 front, SRT6 36 all round it's on the drivers door pillar!!
a couple of psi either way on normal day to day driving will make no difference anyway. :-)
Old Oct 10, 2013 | 07:12 PM
dibri1's Avatar
Thanks for your replies/answers. Seems everyone runs on different pressures! What difference does 3-4 psi make though....is it a safety issue? Been running on 31/32 psi for 3 years without any trouble- tho' did notice steering improved now tyres at 36psi....guess that's because there may be slightly less rubber/tread on the road surface.
Still confused!
(Thanks Mo, but I've lost the sticker with the tyre info on from the door pillar]
Old Oct 10, 2013 | 07:18 PM
pjm30144's Avatar
Door pillar sticker says 32 F 33 R I run .5 more in each
Old Oct 11, 2013 | 02:07 AM
UK-SRT6's Avatar
Default
Still confused!
None what so ever! :-) unless you intend to take part in a F1 Grand Prix lol.
Kodebuster
Nov 5, 2020 04:06 PM
stelrz1
Sep 21, 2015 11:18 AM
lazorouss
Sep 11, 2015 09:16 AM
ardenian
Jul 27, 2015 04:41 PM
pop49
Australia
Jul 6, 2015 10:10 AM
