Uk 2012 Mot Changes
Old Mar 19, 2012 | 03:04 PM
Mr Kilmouski's Avatar
Default Uk 2012 Mot Changes
The Department for Transport is adding a number of new mandatory test items to the annual MOT from 1 January 2012 to comply with a revised European testing directive.
Electronic parking brake
Electronic parking brake controls are now included and must be present and not inappropriately repaired or modified.
The car will fail if an Electronic Parking Brake warning lamp is illuminated to indicate a malfunction.
Electronic Stability Control
Checks of antilock brakes will be extended to include Electronic Stability Control if fitted.
Warning lights
As well as electronic parking brake and electronic stability control warning lights (where fitted) the MOT test will also include checks for the correct function of the following, where fitted;
Headlight main beam warning light
Electronic power steering warning light
Brake fluid level warning light
Tyre pressure monitoring system warning light
Air bag warning light
Seat belt pre-tensioner warning light
Steering & suspension
The new test includes a check on the presence and correct function of the steering lock where fitted as standard.
Missing, or split/damaged dust covers on steering and suspension ball-joints will result in failure if they will allow dirt to enter the joint.
Power steering fluid level must be above the minimum level indicated on the reservoir.
Lighting
Products on the lens or light source that obviously reduce the light's intensity or change its colour will become a reason for failure – applies to front/rear position lamps, registration plate lamps, stop lamps, rear fog and direction indicators,
Headlight requirements are updated to take account of the particular characteristics of High Intensity Discharge (HID) lamps.
HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. A car will fail if a mandatory headlamp cleaning or levelling system is missing, doesn't work or is obviously defective.
Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems.
If a headlamp bulb is not seated correctly the resulting beam pattern will be indistinct and this will result in a test fail.
Electrical wiring and battery
An insecure battery will be a reason for failure as will a battery that is leaking electrolyte.
Visible wiring that is insecure, inadequately supported or likely to cause a short will also result in a failure as will wires bared by damaged insulation.
Trailer/caravan electrical socket
There will be a basic security/damage check of 7-pin sockets,
13-pin sockets will be subject to a full electrical connectivity check and incorrectly connected or inoperative circuits will result in failure.
Tyres
Tyre pressure monitoring systems fitted to vehicles first registered after 1 January 2012 must be working correctly and not indicating a malfunction.
Supplementary restraints
The vehicle will fail the test if any airbag fitted as original equipment is obviously missing or defective.
A seatbelt pre-tensioner fitted as original equipment but missing or that has obviously deployed will be a reason for failure.
Seatbelt load limiters that are missing where fitted as standard or folding webbing type limiters that have obviously deployed are also reasons for failure.
The vehicle will also fail if an SRS malfunction light is missing, not working or indicating a fault.
Speedometer
The car will fail if a speedometer is not fitted, is incomplete, inoperative, has a dial glass broken/missing or cannot be illuminated.
Seats
It must be possible to secure the driver's seat fore and aft adjustment mechanism in two or three different positions. On electric seats the motors must move the seat fore and aft.
Doors
A rear door that cannot be opened from the outside using the relevant control is a new reason for failure.
Doors must be easy to open and close – hinges, catches and pillars will be inspected.
Towbars
Inappropriate repair or modification to the towbar assembly will be a reason for failure if judged likely to affect the roadworthiness of the vehicle/trailer.
Exhaust
A catalytic convertor fitted as original equipment but missing will be a reason for failure.
Fuel system
Damaged or chafed fuel pipes will result in failure.
Old Mar 20, 2012 | 02:19 AM
muskrat's Avatar
Default Re: Uk 2012 Mot Changes
the exhaust one and headlight one should cause some amusement for some people! Whats an electronic parking brake?
Old Mar 20, 2012 | 04:41 AM
waylander's Avatar
I wonder if they'll twig a gutted cat?
An e-brake seems to be the latest thing from Audi et al - it's just a handbrake but electronic why? I guess it frees up a little space?
Old Mar 20, 2012 | 04:45 AM
magredvet's Avatar
Wow............am I glad I don't live in the UK anymore, and have to go through this every year ! Oh that and the $10 a gallon petrol...... We're bitching about $4.50
Old Mar 20, 2012 | 05:56 AM
Alabama 2012 MOT rules :
1. If the vehicle is on concrete blocks instead of wheels, it fails.
2. If the vehicle has not been started for more than 4 years, it fails.
other than that, ur good to go .......
wootto
U.K.
Aug 16, 2020 07:55 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
DaveMe
U.K.
Apr 13, 2016 03:28 AM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
