Clutch
Is the clutch hydraulic if so where is the clutch fluid resiviour please ?? As i have a 6 speed manual sometimes its very fifficult to get 1st gear and also feels like its a bit dragging only when i am pulling away or reversing. Its done 75000 miles.
Sorry I couldn't be of more help. May be some here will know more then me. I use to own a TVR repair shop. I think the Tuscan had a problem with selecting 1st gear. The gear stick use to foul on the body. We had to cut some of the bodywork away to stop this from happening. Good old TVR's. I'm sure this isn't your problem.
Cheers for now
Jon
Cheers for now
Jon
According to workshop manual it's hydraulic (mine's an auto) you may have a symptom of low fluid and I guess the reservoir would be drivers side bulkhead area close to brake reservoir - I downloaded manual from this site
see
Best of Luck
see
Best of Luck
UNDER PSI
Aug 1, 2015 02:11 AM
ricardo 53
Jul 21, 2015 07:49 AM
BlackCrossFire6spd
Aug 21, 2006 10:48 AM
