Front fog lamps
Old May 30, 2013 | 06:49 AM
UK ken's Avatar
Default Front fog lamps
Just replaced bulbs with 80W rather than the standard 55W, no problems with wiring heating up and the lens are glass. The improvement in the light output is noticeable.
My question is, are they adjustable as I feel the beam spread of both is rather low. I realize fog lamps and meant to be low, but not as low as mine are.
UKKen.
Old May 30, 2013 | 07:08 AM
Mrmiata's Avatar
Default Re: Front fog lamps
Washer - shim them at the mounts is probably the only method. No adjustments on the housing itself.
Old May 30, 2013 | 03:52 PM
You might want to reconsider that statement.
Old May 30, 2013 | 03:56 PM
Mrmiata's Avatar
Did I miss noting adjustment screws when I purchased my spare?
Old May 30, 2013 | 04:02 PM
In a word ........... yes.
One adjustment screw and the reflector is located on two pivot points. At least they are on my three spares. Use a 6mm hex key to adjust.
Old May 30, 2013 | 04:04 PM
Mrmiata's Avatar
Hmm.. guess I need more time to stay home and play with my stuff..
UNDER PSI
Nov 1, 2015 09:39 PM
Posimoto
Sep 13, 2015 06:13 PM
Vegaslegal
Sep 10, 2015 11:24 AM
jaesa
Sep 7, 2015 01:50 PM
maxcichon
Sep 4, 2015 12:50 PM
