Need help finding wheels
Old May 25, 2007 | 03:04 PM
jchamberlain's Avatar
Default Need help finding wheels
I have an 04' coupe ltd. I don't know if the tire specs are the same on all x-fires but they are as follows:
Front: 18x7.5", 5x112, ET35, 225/40/18, 66.5 Rear: 19x9", 5x112, ET22, 255/35/19, 66.5
I have had a bit of difficulty finding a set of wheels. Does anyone know of a good place to look? Also I know the x-fires have brake and tire sensors, when purchasing new wheels do I need to be concerned at all with that? In other words will buying new wheels affect those sensors at all? Lastly, what do I need to consider when it comes to the offset of the wheels I am looking for?
Kind of all over the place, but any help would surely be appreciated.
Thanks for your time,
Justin
Old May 25, 2007 | 04:58 PM
ichon's Avatar
Default Re: Need help finding wheels
JC, the first thing to do is pick out a wheel you like and then find out if it will fit. Either way, you may have to disregard the pressure sensors if you decide to go up (or down) in wheel/tire package. Only look for wheels that can be/are "staggered" fit. There is a multitude of wheels/tire packages for the standard XF...Go to Wheels/Tire threads. Check the web for a look you like. MAKE SURE YOU HAVE THE NEW WHEELS MOUNTED AND BALANCED BY A PRO. Good luck and beware...PRICES ARE OUTRAGEOUS.
Old May 25, 2007 | 05:58 PM
Thanks much.
PimpDaddy
Sep 29, 2016 11:55 PM
tom2112
Dec 1, 2015 09:02 AM
princepenson
Jul 29, 2015 07:44 AM
MSCrossfire42
Jul 27, 2015 07:59 PM
Buchacho
Jul 9, 2015 04:13 PM
