Did anyone try putting 18" rims with tires in the back?
Old Nov 8, 2007 | 09:58 AM
banej's Avatar
Default Did anyone try putting 18" rims with tires in the back?
I have a spare 18" rims with winter tires for the front. Did anyone try putting 18" in the back??? This way i would have both 18 in the front and back.
Old Nov 8, 2007 | 11:35 AM
Display_Name's Avatar
Default Re: Did anyone try putting 18" rims with tires in the back?
That's what the owner's manual suggests doing for winter tires.
Old Nov 8, 2007 | 02:36 PM
banej's Avatar
thank you
Old Nov 8, 2007 | 02:40 PM
LantanaTX's Avatar
I have 18x8 in front and 18x9 rear with 225 40 front and 265 40 in the rear. I have a better ride than stock and tires are much cheaper to buy. The improvement in ride is mostly due to less unsprung weight and a little more sidewall. You can see pictures of my set up in my gallery.
Old Nov 8, 2007 | 04:01 PM
pe3046's Avatar
Just put on yesterday my 225/45/18 rear and 225/40/18 fronts. Ride does seem a lot smoother. I am running a set of blizzak lm25's.
Old Nov 8, 2007 | 04:30 PM
kapium's Avatar
I'm putting 225-40-18 on the front and 225-45-18 rear on Sunday for the winter. That keeps the same overall diameter in the rear. Personally, I think Chrysler is stupid for recommending putting 225-40-18 on the rear, being that it's the wrong diameter and introduces speedometer error, which also introduces odometer error. I would rather my warranty didn't run out 4% quicker. Maybe they did it so that you can rotate them? Big deal, most tires are directional, so you can only rotate front - rear anyway. If you wear out the rears replace them, keep the fronts. I'm ranting and I don't even know why... Anyway, I'll post a pic after I mount them if you'd like.
Old Nov 8, 2007 | 08:46 PM
banej's Avatar
Michelin 225/ 40 ZR 18 are these winter tires???
Old Nov 9, 2007 | 06:27 AM
NoCones's Avatar
Can't say without knowing the model (Michelin and the size is not specific enough), but being Z-rated, it's highly doubtful.
Old Nov 14, 2007 | 12:24 PM
calGARY's Avatar
I've put my 19" snows in the rear no need for tire chains ,it stays home if its that bad.
Good info though.Maybe 18" next time i buy.
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Dec 1, 2015 09:02 AM
tom2112
Jul 28, 2015 08:12 AM
axnguyen
Jul 21, 2015 11:41 AM
GWAPA
Jul 8, 2015 07:25 PM
