Rear tires looks tilted inwards
Old May 28, 2008 | 07:17 PM
Dhinson's Avatar
Default Rear tires looks tilted inwards
Does anyones rear tires looks tilted inwards at the top of the tire? I went to a tire shop and they told me the ailgnment is set correctly... The tires are wearing thin on the inside...
Old May 28, 2008 | 07:18 PM
70GT6's Avatar
Default Re: Rear tires looks tilted inwards
That look is normal - wearing like that is not.
Old May 28, 2008 | 07:25 PM
maxcichon's Avatar
Quite right.
Mine are tilted in 5/16" at the lip at the bead (I measured). But there is no uneven wear.
Old May 28, 2008 | 07:29 PM
Dhinson's Avatar
Should I try a wheel alignment? The car does not pull left or right. I drives smoothly
Old May 28, 2008 | 07:31 PM
70GT6's Avatar
Could try another shop for a 2nd check - also check your air pressure.
Old May 28, 2008 | 07:54 PM
+fireamx's Avatar
Has your car been lowered? Does it have "spacers" to give the wheel an offset?
Old May 28, 2008 | 08:02 PM
DrMike's Avatar
Don't worry it's Normal, they sit tilted due to independent suspension. Many cars are like this.
Old May 28, 2008 | 08:17 PM
SRT6nTulsa's Avatar
Mine has a similar tilt, but I do not have uneven tread wear. I don't know what to tell you.
Old May 29, 2008 | 05:22 AM
HyprLtH20's Avatar
www.CustomCrossfire.com
its called camber wear. get the alignment check again but by someone else lol. and do it soon or you are going to need new tires.
Old May 29, 2008 | 07:36 AM
stlas69's Avatar
Mine are tipped in as well and if you do a measurement there is some additional wear on the insde of the tire. I had them checked and was told that's the way it was designed and yes we would wear our tires at a uneven rate.
Old May 29, 2008 | 09:15 AM
eganders's Avatar
Yes, the inward cant or tilt is intentional and normal on your Crossfire. I think it's 2 or 3 degrees, but I'd have to look it up again to be sure. You'll find this handling adjustment to be more common on sports cars. Yes it can cause the tires to wear a bit more on the edge, but generally not a lot. Chalk it up to a small piece of the cost of owning a sports car!
Old May 29, 2008 | 09:24 AM
Dhinson's Avatar
Thanks guys for all your help
Old May 29, 2008 | 10:24 AM
HyprLtH20's Avatar
your eyes will barely notice 2 -3 degrees. if it is as noticable as you say then there is something wrong. it is supposed to have some camber yes...it is to help the car track better but keep it subtle so as to not rip through tires.
Old May 29, 2008 | 11:05 AM
Moparrbust's Avatar
That's negative camber and is present on ALL cars with IRS(Independant Rear Suspension) and is normal.
Old May 30, 2008 | 08:19 PM
Fritzauf's Avatar
That's right... It's normal and there is no rear camber adjustment to change it unless you buy a rear camber adjuster kit and install it. $300 - $400.
PNA
Nov 12, 2020 04:44 PM
MAXIMUM
Aug 4, 2015 11:04 PM
princepenson
Jul 29, 2015 07:44 AM
tom2112
Jul 28, 2015 08:12 AM
Buchacho
Jul 9, 2015 04:13 PM
