help me decide on these wheels.
Old Oct 10, 2008 | 10:24 AM
v8valiant's Avatar
Default help me decide on these wheels.
ok im looking at new wheels for my xfi and i found some i like i want to run a 20x10 with a 275-35or30 -20 rear offset is 42, and a 19x8 with a 225-35-19 the front offset i can get a 45 or a 32 which would work better? will they fit? and whats the common tire sizes when going with bigger wheels i want some tire to protect my wheels but i dont want it to look dumb, also i would like to lower it in the future if that makes any difference in my choices. thanks everyone!
http://www.tsw.com/alloy_wheels_nogaro.php
Old Oct 10, 2008 | 10:43 AM
tighed1's Avatar
Default Re: help me decide on these wheels.
Found a close match at Tire Rack to give you an idea how it might look.
Don't know about fitment on the oversized wheels. Do a search on the forum it's been discussed before.
http://www.tirerack.com/wheels/MiniW...d=true&sw=1280
Old Oct 10, 2008 | 10:56 AM
Fritzauf's Avatar
I think MMZ_Timelord (forum member) has those wheels. I'm sure if you sent him a PM he could help.
I'm pretty sure the stock rear wheel offset is 42mm and the front wheel offset is 32mm.
I stand corrected the Rears are 22mm offset and the Fronts are 35mm offset. Thanks Max.
Old Oct 10, 2008 | 11:02 AM
maxcichon's Avatar
I'm pretty sure the stock rear wheel offset is 42 and the front wheel offset is 32.
Yep, MMZ is running those.
Stock offsets are:
Front 35 mm
Rear 22 mm
Reliableron
Oct 17, 2015 10:19 PM
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
livefreeordie
Sep 22, 2015 08:13 PM
Power Sedan
Sep 20, 2015 09:24 PM
