lug bolt issues
Old Feb 23, 2009 | 12:50 PM
cgocifer's Avatar
Default lug bolt issues
for those who have experienced the too long lug bolt issue, did u have to trim the fronts too? I shortened the rears but not the front. I don't think anything is rubbing but I'm not positive.
I'm using gorilla lock lugs and mandrus milleniums.
thanks in advance!
Old Feb 23, 2009 | 12:58 PM
maxcichon's Avatar
Default Re: lug bolt issues
No, there is nothing behind the hubs there. I think!
Old Feb 23, 2009 | 06:17 PM
MikeR's Avatar
There better not be!!
Old Feb 23, 2009 | 06:43 PM
Moparrbust's Avatar
Just the rears have clearance issues due to the e-brake behind/inside the rotor.
Old Feb 23, 2009 | 07:36 PM
Squirrel Crusher's Avatar
When changing over to custom wheels,would it be so bad to just screw in studs from the back side of the axle backing plate with lock tite added??? Wouldn't that method give us more wheel options? Just ditching the factory lug studs. Squirrel Crusher
Old Feb 23, 2009 | 08:41 PM
NeedsWings's Avatar
if you pull off the wheels and insert the lug studs you can measure the protrusion both stock and with your aftermarket wheels. measure the difference and i can dig thru the mercedes parts films to see if we can find what you need. WE NEED AT LEAST 7 THREADS GRABBING!
Old Feb 23, 2009 | 08:51 PM
cgocifer's Avatar
I only removed about 3/16th - to just under a 1/4 of an inch from each rear lug bolt. They were just barely hitting the e-brake springs. The whole effort took about 15 minutes per wheel including the removal and re-installation. Piece of cake!
55chevy
Jul 22, 2024 02:31 PM
pioneer4x4
Mar 18, 2021 02:17 PM
Bob4kacz
Sep 16, 2015 11:20 AM
bobbie
Sep 12, 2015 12:49 PM
MickeyNasty
Sep 6, 2015 08:29 PM
