ebc VS. posi-quiet
HI I HAVE BEEN RESEARCHING BRAKE PADS AND IT SEEMS THAT MOST PEOPLE ARE SET EATIER ON EBC GREEN STUFF OR POSI-QUIET CERAMIC BRAKE PADS. I DIDNT CONSIDER ROTEX BECAUSE OF THE NOISE.
I WAS WONDERING WHAT ARE THE PROS AND CONS OF EACH BRAND. I WAS LEANING TOWARDS POSI-QUIET BECAUSE ITS MADE THE SAME WAY AS OME BRAKEPADS?
I have the Posi-Quiets and love them. They seem to last forever and don't seem to wear the rotors at all with no dust. Great stopping as well. I put 20,000 miles on a set and they still looked brand new and my rotors were smooth and perfect. What more could you ask for? They have squealed backing out of my drive only a couple of times after washing the car and not driving the car right away. The pads don't seem to like any surface rust on the rotors, but this goes away instantly the first time you use the brakes.
Originally Posted by Tamadx
i just ahte the brake dust of the stock ones... but they are still workin well soo i dont plan on changing them
are the posi quiets stupidly expensive?
I also got the same deal on Ebay and did all four corners for the price of just Rotex fronts. I have 40K miles and the rotors didn't look great. I didn't turn them but after a while the rotors were smooth like brand new and within the min thickness!
I have read nothing but good things about Rotex Golds. Are they really noisy?
Question: may I assume that I should choose the SLK32 model of posi-quiets for the set that fits the SRT6?
Thanks for your advice!
Thanks again for the confirmation! I'm on my way to getting them too then ;-)
Thanks for all the great information. I have about 67,000 miles on my crossfire should i change the rotors as well I think they are the original ones (I bought the car used).
Originally Posted by faiz23
check out EBC red stuff more aggressive than green. I had green on my acura and loved it over stock well worth it but i think i will try red next little more aggressive.
Originally Posted by ImportLabSRT
FYI... Reds are a very loud pad when they are cold because of the material compound.Get the pad over 150deg and the squeal goes away.
Hope they run as well as they should, now onto SS lines and racing DOT fluid.
Originally Posted by 05XF-LVR
Thanks for the info, was considering red and just bought disc italia ceramic pads and cross drilled / slotted disc italia rotors
dedwards0323
Nov 16, 2009 01:44 PM
nate_man
15
Dec 28, 2008 09:12 AM
