Eibachs on SRT: upgrade or downgrade
Old Nov 19, 2009 | 09:03 PM
mrphotoman's Avatar
Default Re: Eibachs on SRT: upgrade or downgrade
Duh, i should have seen your location in your profile lol. I remember your 2006 now too
Good job on those runs!
Old Nov 22, 2009 | 01:02 PM
velociabstract's Avatar
This review only pertains to Eibachs on a SRT-6 and not N/A Crossfire.
Well the results are in. Eibachs are an appearance item. The car looks great, the ride I find a bit bouncy but that could be more the shock settings. The dive on braking is worse than the stock SRT springs and my times were much slower. As far as rubbing I'm getting a little on the inside of the front fenders even with the 5 dot pad, but it's so slight that I doesn't really matter. For outright performance for a SRT I'd look elsewhere. Right now, as we speak, I think eventually I'll cut the stock springs or pay the price and get Bilstein PSS9's. If you track your SRT don't waste you time or money on Eibachs. IMO
I'm real disappointed.
Les
Old Nov 22, 2009 | 07:24 PM
mrphotoman's Avatar
Les
sorry to hear the news after all that work and thank you for the follow up. i was afraid that would be the results
Old Nov 22, 2009 | 07:45 PM
I made other changes along with the springs which I plan to undo before I yank them out and cuss them until they change color. Also I'm going to work with the springs before putting them up for sale. Maybe put in a spring rubber like in Nascar.
On a side note, I was moved up to the fast class and I'm going to need more power next year. Those modified Subi's are putting out 450 at the wheels. Also the organizing body is talking about new requirements for track time. It seems the street cars are faster than some of the race cars now and they may insist on a roll cage. (I did outrun a few race cars myself)
It's clear to me now that Eibach's are a street spring, at least what they sell for the Crossfires.
I'm going to ponder K&W coilovers too. The spring rate on the front is 680 which sounds about right to me.
Les
Old Nov 22, 2009 | 09:53 PM
mrphotoman's Avatar
Les
i used spring rubbers on my last car with great success, the kind that wraps around your springs is expensive but work and stay very well. The set I had were $45.00 each! Pricey but worked well. I still have them somewhere. I think i suggested them to woody in a thread on here when he was asking about an aftermarket rear sway bar last year.
I may have the link where i bought them, i will check tomorrow. you could get different heights and stiffness on them, i used the medium or hard i do not recall. you can also get spring clamps to use with the spring rubbers to ensure 100% that they do not come out. i have a few sets of those as well.
Old Nov 22, 2009 | 11:39 PM
Infinite's Avatar
whoever said the spring rates are 451 front 480 rear has them backwards.
no fr layout car in the world has stiffer springs in the rear then the front.
Old Nov 23, 2009 | 12:02 AM
bmorgan's Avatar
Les
As I didn't want to cut my stock springs in case I wanted to put it back to original later, I bought a set of SRT springs from a forum member for $50. I cut those and put them on. I have to say that I am extremely pleased with them so far.
Old Nov 26, 2009 | 12:15 PM
Some new developments today. I suspected that the shop that did the instal didn't cut the bump stops so I got out the tools and went to the basement to check out the instal. To keep a long story short, one of the front springs is installed upside down. The rear bump stops were not trimmed either. I took care of the bump stops but the shop will have to do the spring. I took pictures of the rubbing etc and will post them later today or tomorrow. I guess I'll give the springs another track day before I make a final decision about yanking them out or working with them. The word is, check the work you pay to have done, you never know for sure if it's done right.
Les
Old Nov 30, 2009 | 07:39 PM
I got a couple of photos of my car cornering. It looks pretty good in the corner, to me. What do you think? I had negative camber in the rear and it made the rear of the car real nervous. I'm going to undo most of it before the next track day.
Les
Old Nov 30, 2009 | 09:09 PM
mrphotoman's Avatar
yeah it looks pretty good, i see you have a gopro video cam too. i need to get one of those!
wow that is some tape job, how long did that take?
Old Nov 30, 2009 | 09:30 PM
I use the Gopro all the time and I like it but in low light the video is dark. I hear the new version fixes a lot of the things people criticize about the original. Low battery life for example. I forgot to empty the memory card in the camera so I didn't get much video. The tape job? Oh I'd say 20 to 30 minutes. I didn't tape the car my first track day and ...... now I always tape it. As a matter of fact, I'm looking at other products because I want to put the tape with a plastic product on top. The rocks will often leave a mark regardless of the tape. I see 115 or more on the straight and most cars are running soft compound tires which pick up and throw everything.
Now that I see the pictures in the corner I'm thinking my "new alignment" needs changing. I've got a Pyrometer coming soon to take some of the guess work out of the equation.
Les
Old Jan 27, 2011 | 07:11 AM
I decided to return to give a new update. I wanted to give them another chance now that I'm more knowledgeable adjusting the car so I reinstalled the Eibachs in the rear (easier than the front) and tried a couple of different spring pads for different ride heights. I've done 2 track days with them and another day of testing at a track and they come out this afternoon. I tried different alignments (toe and camber) and lots of air pressure changes but nothing I've tried has resulted in quicker track times. As a matter of fact, they made the car crazy loose when combined with the stock springs in the front. They are fine for day to day and spirited driving but for racing they can't be made to work as well as the stock springs IMO.
Les
Old Jan 27, 2011 | 09:33 AM
tunaglove's Avatar
Les, how about street driving? Sometimes my SRT just seemes too stiff for a DD.
Old Jan 27, 2011 | 10:01 AM
JHM2K's Avatar
Les
Old Jan 27, 2011 | 11:36 AM
They ride much better on the street than the stock springs. I would say, very comfy. My issues with them is at the limits of traction. With the Eibach's the limit comes sooner than with the stock springs. Franky, the car is scary loose in all the corners. (I'm talking warp speed) I feel fast with them and with the my stock cut springs but the timer always says the stock springs are faster ..... and by quite a bit. I don't know why but thats the way it is.
Les
Old Jan 29, 2011 | 01:32 PM
freakingfastsrt6's Avatar
Ive run the pro kits on my car since 2007 and have tracked at willow springs numerous times...I love the feel over stock...though im running different tire and wheels sizes...Im running tsw 19x9 front and 19x10 rear with 235 35 19 front and 295 30 19 rear...I have had no issues and love the set up, not bouncy at all and corners flawless and effortlessly....My opinion...it handles much better than my c5 vette
Old Jan 29, 2011 | 01:36 PM
Les
Im surprised you like the feel of cut springs...I couldnt stand it!
I cut my springs back 2005 when I first bought my car... needless to say I was confused and wanted the lowered look...But at the end of the my back said enough!!!!! No more bouncyness!!!!! Never cut your springs people the ride is horrible!!! My two cents!
Old Jan 29, 2011 | 05:12 PM
  #38 (permalink)
I gave specific instructions when my springs were cut. Plenty of lubrication to keep the heat from the process under control.
Most people that have the Eibach's absolutely love them. I find it odd as you do and for that reason I keep putting the Eibach's in and giving them another chance. But I've given up. It's possible that I got a bad set....?????
I took the Eibach's out again yesterday and I have the stock cut springs installed. My plan is to get a spring tester and see exactly what spring rate they have after the cutting. That way I'll know what height and spring rate to get from Hypercoil or the like.
Les
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 28, 2015 07:40 PM
ayebb
Sep 18, 2015 03:35 PM
RacerXofFL
Sep 15, 2015 05:00 PM
