spacer size with eibach spring pro kit
Old Nov 19, 2009 | 10:50 AM
carpen04's Avatar
Default spacer size with eibach spring pro kit
hey i am about to buy eibach pro spring kit and i have 15 mm spacers in the back and 12mm in the front..i like the stance of the car now..but my question is if i lower the car will the 15 mm in the back and 12 mm in front rubb any? thanks, Nicholas
Old Nov 27, 2009 | 04:25 PM
former NXMX5's Avatar
Default Re: spacer size with eibach spring pro kit
as soon as you lower it the car will rub some, especially in reverse.
i would personally stick with 10mm front and 12mm rear. and dont forget your longer lug bolts
Old Nov 27, 2009 | 04:49 PM
velociabstract's Avatar
I have the Eibach Pro kit. I have 10 mm spacers on the front and none in the back. I rub inside the fender well but not bad enough to worry about. The tire clears the fender rim. I think you will be okay in the front. I don't have a clue how you'll make out in the rear. I say go for it and let us know how it works out.
Les
Old Nov 27, 2009 | 05:36 PM
Yep, I have the 12mm and 10mm rear and front respectively with no issues. I don't know that a few mm will make a difference.
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
mattnelson71
Jul 30, 2015 10:49 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
crymar
Jul 17, 2015 08:46 AM
syfi
Jul 12, 2015 05:59 PM
