Eibachs and Spacers HELP!
Old Mar 29, 2010 | 04:37 PM
macavelli24's Avatar
Default Eibachs and Spacers HELP!
I've done some seaching on the forum, and I can't seem to find a clear answer. Is there anyway to run the Eibach springs with out spacers? I'm putting my stock wheels back on and I hated the spacers I had to use with my after market wheels. I really want to lower my car but I also really don't want to use spacers. Any info will help, thank you!
-Sean
Old Mar 29, 2010 | 05:05 PM
bmorgan's Avatar
Default Re: Eibachs and Spacers HELP!
You should do not need to use spacers with Eibachs. I have mine lowered the equivalent to the Eibachs, and do not use any spacers.
Old Mar 29, 2010 | 05:27 PM
velociabstract's Avatar
No spacers needed with stock size tires and Eibach's. But you need to use spring pads. The stock ones may make too low in the front with the Eibach's, but I don't know positively.
Les
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 26, 2015 10:21 PM
ayebb
Sep 18, 2015 03:35 PM
04Fire
Sep 15, 2015 07:40 PM
