Anyone not using their OEM wheels centers?
Old Apr 25, 2010 | 03:26 PM
naudi90's Avatar
Default Re: Anyone not using their OEM wheels centers?
To be clear for the SRT folk, these caps fit our wheels?
Mercedes caps on ebay
When I measure the inside diameter of the center of our wheels, 72mm looks too big?
I want these so just looking for confirmation from someone that has installed them.
Thanks!
Old Apr 25, 2010 | 03:37 PM
MikeR's Avatar
I just measured my front hub.... 72mm.... I have the silver ///AMG logo caps and they fit fine....
Old Apr 25, 2010 | 05:05 PM
naudi90's Avatar
Great thanks!
Old Apr 25, 2010 | 06:08 PM
Yep, the issue I believe is only withe NA wheels.
Old Apr 25, 2010 | 06:53 PM
bmorgan's Avatar
Thanks!
Look at post # 4. Those are the ones that I have on my car. For some reason, these are not as good of a fit as all of the others. Several people have bought these and have the same problem in that they are a bit loose. They are easy to modify though. Just remove the metal spring clip from the back and throw away. Then, heat each of the tabs at the base with a cigarette lighter an use pliers to bend the tabs slightly outwards at the base. They will then fit very snug.
Old Apr 25, 2010 | 06:55 PM
IBLUBYU's Avatar
I ordered the silver AMG discs from the same vendor (lexius ??) recently, and eventho the diameter was right (75mm/72mm) they wouldn't work on my SRT wheels, because the back legs on the discs were too deep to fit the hub and snug them to the wheel. (Hope I explained this right) I ordered them because of what I read, these "mercedes" discs would fit on the crossfire hubs (because of the MB heritage). BTW ... the discs I got had BRABUS marked on the backs.
Just read Morgans post above (crossed in the mail LOL) I guess I'll try the alteration , hope it works, Nothing to lose because they're worthless now...l
Old Apr 25, 2010 | 07:02 PM
bmorgan's Avatar
Originally Posted by IBLUBYU
I ordered the AMG discs from the same vendor (lexius ??) recently, and eventho the diameter was right (75mm/72mm) they wouldn't work on my SRT wheels, because the back legs on the discs were too deep to fit the hub and snug them to the wheel. (Hope I explained this right) I ordered them because of what I read, these "mercedes" discs would fit on the crossfire hubs (because of the MB heritage). BTW ... the discs I got had BRABUS marked on the backs.
See my previous post... #25. Everyone that has bought these have had to modify them. Having said that, it only took less than 10 minutes to fix them, and I love them. I have been running with them for about 5 months now, and would not consider changing to anything else.
Old Apr 25, 2010 | 07:03 PM
bmorgan's Avatar
LOL...... we are just missing each other.
Yeah, if they have a 1/4 to 1/2 inch play in and out after you put them on, that is the same as the colored AMG ones, and my method will definitely work..
Old Apr 25, 2010 | 07:11 PM
IBLUBYU's Avatar
If I can't get them to fit, I might drive down to Warner-Robins and let you do it... LMAO
Old Apr 25, 2010 | 07:29 PM
bmorgan's Avatar
Where are you located? If you are close by, you should come down next weekend to run in the Import Showdown with me, 32Krazy!, and possibly XRay.
EDIT: Buggin may run his SLK32 also.
Old Apr 25, 2010 | 07:58 PM
IBLUBYU's Avatar
Located in Illinois .... so just kiddin!! BTW ... where did you get the black caps for your lug bolts. Looks great!
Old Apr 25, 2010 | 08:02 PM
bmorgan's Avatar
I got my bolt covers from this ebay seller. Good price IMO. FREE SHIPPING! NEW MERCEDES BLACK LUG BOLT COVERS 20PCS : eBay Motors (item 130385596587 end time Apr-30-10 10:50:55 PDT)
Old Apr 25, 2010 | 08:39 PM
Mocephus's Avatar
Originally Posted by tpoag
Looks good! Did you find a center cap that fit or did you have to modify one?
Well both, really. The caps I found on ebay were Mercedes AMG caps with 57mm ID and 60mm OD. When I went to install them, they fit in the center hole with slight resistance, but nowhere near enough (they actually fell out on their own).
I noticed they use the same style tensioning "C" spring as the OEM caps, but smaller. I carefully swapped the spring clip, which forced the locking tabs out a little more, which then held tight. One issue, the caps on the rear rims will not come out, but they rattle slightly. I got a large diameter O-Ring and used that as a "shim". I need to find a slightly thinner o-ring, which will completely hide it from view. The front actually fit in tight with no play at all. Weird.
Old Apr 28, 2010 | 10:03 PM
tpoag's Avatar
Thanks for the info...I will look on Ebay and see what I can find in that size
Old Apr 29, 2010 | 12:29 AM
Mocephus's Avatar
These are the ones I bought,
Mercedes Benz AMG Wheel Center Cap S600 E63 C32 SLK55 : eBay Motors (item 330428467309 end time May-05-10 10:52:57 PDT)
Old Apr 29, 2010 | 05:49 AM
Erzer's Avatar
Originally Posted by FP
The down side of storing my car during the winters is that come Spring, I have the bug to do something to the car. Does it ever end?
I need meds, I think....
Now you can go buy that carbon fiber hood MadMed designed....
Old Apr 29, 2010 | 06:28 PM
tpoag's Avatar
I found those on Ebay....it says there are made out of aluminum. Are the tabs aluminum or plastic? I will probably order a set tonight. Thanks again!
Old Apr 29, 2010 | 07:07 PM
  #38 (permalink)
Mocephus's Avatar
The wording is a little misleading. The BADGE is made of aluminum, covered in some clear, domed material (actually quite nicely done). The center cap is actually plastic.
Old Jul 15, 2016 | 12:11 PM
  #39 (permalink)
danielalexander81's Avatar
Originally Posted by bmorgan
FP, I think you have seen mine before, but here they are.
Where did you get those center caps and lugs from? I just picked up these rims and am looking to put some flare on them.
Old Jul 15, 2016 | 12:40 PM
  #40 (permalink)
Those look great! Don't know where he got them from but I bet they are hard to keep 'bolts painted' and nooks/crannies on the rims clean!
