Creak/Squeak In Steering
This noise is so annoying and embaressing. It's only when I turn my steering to the left. I checked my power steering fluid and it's fine. It only happens when I'm stationary or at low speeds and only when I turn to the left. It's not brakes definatly something in the steering column I'm lost as to what it could be?
Jack it up on safe supports and have someone look under the hood while you rock the steering back and forth. I suspect that the noise is in the column its self. THe assistant will at lease be able to tell you which side its coming from, and give you more data. Woody
Possibly the steering damper
https://www.crossfireforum.org/forum...surprised.html
Originally Posted by 04Fire
I've put almost 7k on the new damper... from JoelTLC... and it's already shot and now makes a horrible grinding noise every time I turn the wheel at low speeds. So needless to say it needs to be replaced... so does anyone recommend or know of a different brand with a little longer life span? I know it's only $30 but gees.
Chrysler's Part #: 68032068aa (price range from $430-$600)
Had a minor creak that was gone after replacing the damper
cdcrone123
Sep 20, 2015 10:02 PM
