Acceptable Snow Tire Sizes
I am in the market for some snow tires. I couldn't find any info on the threshold of sizes that will not throw off the TC. From what I've read, as long as the height is within 3% it will be fine. This means 25.24-26.8" for the rear and 24.25-25.75" for the front. Is anyone running tires within this range?
Not sure. I just put Conti Extreme Contact DWS on my XFire for the winter. I went with 235/40/18 on the front and 285/35/19 on the rear. Those are a little taller and wider than stock. Drove in the snow for the first time yesterday and was impressed with these tires.
225/40-18 up front and 255/35-19 out back with blizzak LM-25s, ran them last year for first time and have been impressed ever since.
Especially since the 265s were on clearance on tire rack.
The owners manual recommends that you get a second set of front rims, and run the front size tires on the back wheels with snow tires.
Would be cheaper than buying a set of 19" rear tires in the stock size, that's for sure.
Not to mention better traction in snow with the thinner rear tires.
BC.
BC.
BC.
BC.
I picked up the MB wheels and just put them on the rear... the taller tire in the rear works, and I can actually blow the tires off without upsetting the traction control now. I am definately happier with the smaller wheels and plan on switching out the fronts as well (that's why I didn't clean them). I might make up some adjustable control arms to fix my rear alignment though, I didnt realize how much the tires rub.
Is it just me, or do the rears sit inside the wheel wells pretty far?
I can appreciate the functionality and cost savings, I think it looks comical to have a wheel like this on the XF since the OEM are so large....
To each his own, I am sure some thought my last 20's were comical looking too
BrenLW
Aug 5, 2015 04:53 AM
syfi
Jul 12, 2015 05:59 PM
