Tire Questions
The steering on my roadster (2008 Limited w/ 19,500 miles and original tires) has gotten loose so I took it to the dealership this morning to have the steering dampner replaced while the car is still under warranty. The technician said that he'd install a new dampner when it arrives; however, he didn't believe that would necessarily solve the problem. He thought the loose handling could be due to a bad belt in the front driver's-side tire. He showed me a slight wear pattern but I could barely see or feel it when the tire was spun.
My questions:
1. If a belt has slippled, how soon do I need to replace it? There's still quite a bit of tread left and the car handles well on smooth roads.
My questions:
2. Do I need to replace both front tires? If not, I'll just get a matching one.
3. If I have to replace both front tires, I'll likely replace all four with Hanok Ventus V12 evo K110s. Am I overkilling the problem when there's over 50% life left in the back tires?
Thanks in advance for your advice!
If it were me, I'd just replace the defective tire. You've still got quite a bit of usable tire life left in the remaing three tires. However, if your driving style is aggressive, I'd buy the new set of Hankooks you are thinking about.
Kodebuster
Nov 5, 2020 04:06 PM
xfireohio
Jul 20, 2020 12:03 AM
MAXIMUM
Aug 4, 2015 11:04 PM
Bayukbros
Jul 29, 2015 10:16 AM
axnguyen
Jul 21, 2015 11:41 AM
