Rear brake upgrade
Hello all... I have been doing a lot of reading and search on here, MBWorld and other MB sites for rear brake upgrade options. In a perfect world I would like a 4 piston rear caliper that uses the stock 300mm rear disc but that does not seem to exist. Next option was 05 CLK/SLK55 rear calipers and 345mm discs but I cannot seem to find a source to match my front rotors I have.
Maybe I should just sell the kit I have now but they only have 150 miles on them and its depressing to think of how money I would lose and the price to ship everything. Enough ranting.....Do 4 piston rear calipers that work with 300mm discs exist??
Thanks,
Bryan
Thanks,
Bryan
Originally Posted by 32krazy!
not that im aware of bryan. but the slk55 arent 345 rather 330 mm rears that are drilled and slotted. what fronts do you have?
factory slk55 rotors are approx 375$ a set and are drilled and slotted. be aware that running 4 pots in the rear wont allow you to run drag wheels less than 18" (ie: clk rims voxx 17") i tried 3 different sets and had to go to a 18" rim which also limits the dr's available to you.
cl55 or certain s600 calipers will work much cheaper and all you need is a 10mm id x 12mm od x 19mm tall aluminum sleeve to insert into the caliper mount holes and its plug and play rudy can help you with the part # and sourcing them if thats the route you want to go.
Originally Posted by ImportLabSRT
Factory S600 wheels are 17" so maybe I will chance the S600 calipers if I decide that I actually need 4 piston rear calipers. If I do that then Ill have to go with 6 piston fronts too
Really... you start this thread yesterday just when I picked up 4 boxed of these... Here is another option if someone does not want to mess around getting different parts from different cars.
4 pot rears. I will take more pics if you want
Great looking brake set up.
The label on that Coors Light is blue and ready for consumption. I'll bet it didn't lay on it's side for too long with you around.
savings of approx 1500$ by researching a bit and watching for the right parts. of course the entire slk55 setup can be purchased at oediscountparts.com for about 4200$
