tire question
Old Apr 25, 2013 | 09:16 AM
figgy7935's Avatar
Default tire question
My wife had a blow out on a rear tire. I just purchased these tires less than a year ago. They run 425.00 each and was wondering if I should replace with the same tire or buy a pair of less expensive tires so they would be the same on the rear. I was wondering if any of you might have a source for better pricing on tires that you would share with me.
I have Michelin 255/35ZR19 Radial X on the rear
Thanks
John
Old Apr 25, 2013 | 12:46 PM
Default Re: tire question
Where are you located? I would replace it with the same tire. Should be a warranty unless she cut it on something. The should pro rate the tread wear and discount the new tire. If she cut it then no warranty.
Old Apr 25, 2013 | 02:07 PM
cjw's Avatar
cjw
I would try a different tire, that's a lot of money for a Michelin, I'm not too knowledgeable on high mileage tires but I know that they're are many sticker ties out there cheaper, like doc said if it's warranted go for that
Old Apr 25, 2013 | 08:41 PM
itsky's Avatar
Depends on how much you drive the car and the style that you drive. I have a heavy foot and can go through a set of rears every 12K or so. With that, I generally will buy a cheaper tire.
Kodebuster
Nov 5, 2020 04:06 PM
xfireohio
Jul 20, 2020 12:03 AM
MAXIMUM
Aug 4, 2015 11:04 PM
Bayukbros
Jul 29, 2015 10:16 AM
axnguyen
Jul 21, 2015 11:41 AM
