tire "frozen" to to rotor
Old Jul 4, 2014 | 07:19 PM
deltacrossfirebob's Avatar
Default tire "frozen" to to rotor
trying to take the tires off of the car.
took lug bolts out but tire will not come off.
need advice/help.
thanks
Old Jul 4, 2014 | 07:54 PM
Toolman's Avatar
Default Re: tire "frozen" to to rotor
We had the same problem with my son's Crossfire. The way we got them off was to raise the car with the jack, so the wheel was just barely off the ground. We then took a 2 inch diameter by 5 foot long pipe, and with a combination swing while dragging it on the driveway to avoid hitting the wheel, we whacked the bottom of the tire (Inside going outward). I expect a 2x4 would work as well. One or two good hits on the tires had them come off.
The wheels had corroded around the center hole. Before putting the wheels back on we cleaned the center holes, and put some anti seize grease around them before re-installing the wheel on the car. That has worked well and we have not had any problems after that.
Old Jul 4, 2014 | 08:13 PM
need advice/help.
thanks
An old trick is to loosen the bolts and drive it slowly in circles until the wheel is loosened.
By loose I mean a few thou gap, not loose loose.
Old Jul 5, 2014 | 12:02 AM
thanks for the input.
will be giving them a try.
have put some ballitsrol, similar to wd-40 and completely biodegradable, thru the lug holes.
something will work
Old Jul 5, 2014 | 02:13 AM
MoparFreak69's Avatar
Or just give the tire a healthy kick. The wheels are subjected to much more force than you can give it in a kick. Old school, low tech method that always works.
Old Jul 5, 2014 | 01:12 PM
with a combo of all your input.......they are off.
working on taking the calibers off and there is a "caliber slide pin".
how does this slide off??
took off end dust cap but can not see how to remove it.
looking forward to replacing it and there is torque specs of 25 but how does it come out??
thanks again for all the great help.
Old Jul 5, 2014 | 04:10 PM
found an old thread with comments from andrew, seems it takes a 7mm to unscrew that floating pin.
thank you andrew and old postings.
now it is that dang star bolt holding the wear sensor
what was once a simple job sure gets difficult with old age, body just doesn't do the same any more, but it is fun.
thanks guys
Old Jul 5, 2014 | 04:44 PM
Bob, the caliper pins are actually T47 star, not 7mm, although that will work in a pinch.
that
is a T40.
Old Jul 6, 2014 | 01:14 PM
one wheel off and black plastic dipped/sprayed.
caliper off and cleaning to spray red.
now it is the rotor that is frozen.
never before have i had such problems with dis-similar metals n a car.
gonna have lots of anti-seize on hand when putting back together.
thanks again for all your help
Old Jul 6, 2014 | 02:31 PM
Does it have one screw to hold it on?
I have forgotten what mine where like.
Old Jul 6, 2014 | 02:42 PM
thanks for your previous help.
yes, there was on small screw holding it in place.
it is out.
tried wacking it with mallet, lower the car with a floor jack to put some weight on rotor to maybe break it loose, so far no luck.
Old Jul 7, 2014 | 06:10 PM
Toolman's Avatar
it is out.
If it's a rear rotor that will not come off it could be you have the parking brake pulled. The parking brake shoes press outward on the rear rotors. They will not come off with the parking brake on.
TerryR
Dec 13, 2019 03:27 PM
Mackel
Sep 29, 2015 02:41 PM
leaddog2015
Sep 26, 2015 08:23 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
nmfox
Sep 23, 2015 06:39 PM
