Cross-Drilled / Slotted vs. Cross-Drilled Rotors
Old Mar 1, 2015 | 06:54 AM
Default Cross-Drilled / Slotted vs. Cross-Drilled Rotors
Did a search and couldn't really find any posts that addressed this comparison. Thinking of upgrading my rotors and was wondering what other owners felt about any performance characteristics and/or benefits between Cross-Drilled & Slotted versus only Cross-Drilled rotors.
Thanks,
Old Mar 1, 2015 | 01:12 PM
Default Re: Cross-Drilled / Slotted vs. Cross-Drilled Rotors
I have cross drilled on the roadster. After changing out the rotors, I realized just how good the stock rotors are. So, I elected to keep them on the coupe and just did my line, fluid and pad upgrades instead. I see zero difference in stopping power. The theory if round track racing, is cooling and such...so thats my take...
Old Mar 1, 2015 | 02:01 PM
dinasrt's Avatar
Thanks,
My understanding is that for track use(performance), the slotted only rotors are more desirable. The cross drilled rotors and slotted rotors are better at removing water, but because of the surface area removed from all the drilling, they have slightly less stopping power than just the slotted. And at the higher temperatures inflicted at the track, are more vulnerable to heat cracking and warping. The quality of the steel and manufacturing of the rotor is the more important concern I believe(no cheap pirated China knockoffs). IMHO, and in attempt to answer your question, I think the Cross-Drilled & Slotted rotors would remove more water quicker than just the Cross-Drilled, and look pretty cool as well. Also, the quality Cross-Drilled rotors have the holes that are countersunk rounded.
Old Mar 1, 2015 | 04:58 PM
KDW4Him's Avatar
By stock do you mean an original OEM part or aftermarket. If aftermarket which one?
Valk
Jun 22, 2025 09:15 PM
oldbiff
Mar 19, 2023 11:37 AM
leaddog2015
Sep 26, 2015 08:23 PM
AlbertFattal
Sep 24, 2015 05:03 AM
nmfox
Sep 23, 2015 06:39 PM
