Car shakes when I brake
Old Aug 1, 2015 | 11:47 PM
chturner's Avatar
Default Car shakes when I brake
The front of my car shakes when I brake so I'm assuming it is warped rotors on the front because the back does not shake at all. Any advice? If it's the rotors, who has good deals on them? I tried searching this but could not find anything. My exhaust can wait because I'd rather have my car performing like it's still new.
Old Aug 1, 2015 | 11:58 PM
Default Re: Car shakes when I brake
I have had good luck with these
CENTRIC PREMIUM BRAKE ROTORS - Centric Parts
They are available on many other websites so shop around for the best price
Also if you are buying new pads I also have had great results with Posi-Quiet ceramic brake pads
POSIQUIET - Centric Parts
Old Aug 2, 2015 | 07:50 AM
RED DOG's Avatar
Hi chturner, Do you have an NA or an SRT6? Will you please take a moment to update your profile (see link below) so we can know a bit more about you and your Crossfire without having to ask basic questions?
https://www.crossfireforum.org/forum...tml#post812689
I recommend brakeperformance.com. Good customer service / Top quality products with a lifetime warranty.
Old Aug 2, 2015 | 09:55 AM
maxcichon's Avatar
chturner,
I have a set of OEM's sitting in my lab. Where are you? PM me.
~12K miles.
Free for shipping.
Old Aug 2, 2015 | 03:56 PM
chturner's Avatar
I will when I get off work and get to my laptop. I mostly use the browser on my phone to forum browse. It's an NA though to answer your question
Old Aug 2, 2015 | 11:23 PM
JEFASOLD's Avatar
Make sure that it's not something loose or broken in the front suspension or a bad alignment. The stock front rotors are vented and fairly thick, they do not easily warp.
Old Aug 2, 2015 | 11:25 PM
chturner's Avatar
If I lightly press the brake then it does not shake but when I put a fair amount of pressure on them they shake violently. How would you suggest I check the suspension? Will a regular mom and pop garage be able to align it or does it have to be one of the fancy laser alignments?
Old Aug 3, 2015 | 09:55 AM
maxcichon's Avatar
This is sage advice. Put it up on a lift and look things over. Might be as simple as a loose caliper mount!
I PM'ed you. I'll make sure I still have my OEM rotors.
Old Aug 3, 2015 | 11:11 AM
maxcichon's Avatar
I do still have them. PM sent.
Old Aug 3, 2015 | 12:31 PM
chturner's Avatar
I'll go jack it up right now. Thanks again
Old Aug 3, 2015 | 01:15 PM
chturner's Avatar
Rotors are in fact warped. Spin freely half the rotation and barely spin the other half.
Old Aug 4, 2015 | 08:53 AM
maxcichon's Avatar
2 things: with the wheel removed, the rotors are held in place with 1 small screw. On one side. If there is crud trapped underneath, you would never know.
I would remove the rotor (I know-you have to disassemble the calipers, bummer) and make sure it's very clean under the rotor. A .005" piece of grit will make your brakes act this way.
And I PM'ed you!
Old Aug 4, 2015 | 03:24 PM
cmz's Avatar
cmz
If the rotors are still at stock thickness, you can have them turned down on a lathe. Brake shops and some parts stores provide this service.
Old Aug 5, 2015 | 03:11 PM
maxcichon's Avatar
And of course!
Why didn't I, or anyone else, suggest this? Duh!
Old Aug 5, 2015 | 04:24 PM
chturner's Avatar
And of course!
I think I'd rather take a trip to Alabama and let Mad Max teach me how to do it
Old Aug 5, 2015 | 06:33 PM
Max has the knowledge, skills and tools, however I have the Air Conditioned shop.
We do most of our heavy lifting here.
Old Aug 5, 2015 | 06:51 PM
maxcichon's Avatar
And a damned fine cook happens to live there, too. Bring gifts!
Old Aug 5, 2015 | 08:36 PM
chturner's Avatar
I should move to Alabama then
mhajek18
Dec 30, 2015 03:40 PM
BibaResto
Jul 4, 2015 03:20 PM
WindRestrictor
Jun 16, 2015 12:18 PM
WindRestrictor
Jun 1, 2015 02:31 PM
lazorouss
May 29, 2015 08:28 PM
