Handbrake shoes
Old Jul 15, 2016 | 11:45 AM
Crossfiren's Avatar
Default Handbrake shoes
Hi
I must change the pads for handbrake.
Is there something especially to think about
Its a Crossfire 3,2 2004
Regards
Old Jul 15, 2016 | 11:50 AM
Default Re: Handbrake shoes
Originally Posted by Crossfiren
Hi
Regards
Yes, download the service manual and read, read, read. If you cannot understand the instructions then find a helpful member local to you and between the two of you, it should be no problem (with simple basic tools of course).
Old Jul 15, 2016 | 12:20 PM
Crossfiren's Avatar
Maybe not need to change shoes only adjust the handbrake.
what would you tried first?
Old Jul 15, 2016 | 12:37 PM
As stated, first download the service manual, it will tell you how to first inspect. From there, either adjust (unless something damaged the cable I do not think it would be a problem), or replace, the shoes. If your not confident you can do these things, find a member local, and invite to dinner. Many members would like to help just finding him/her might be problematic. Good luck!
Old Jul 15, 2016 | 01:27 PM
I can not see these shoes EVER wearing out.
Surely someone would never try to stop the car with the hand brake on a regular basis.
Old Jul 15, 2016 | 01:42 PM
Crossfiren's Avatar
the car has run 130 000km.
i will look in the manual before i buy new brakes.
Old Jul 15, 2016 | 02:11 PM
I was just saying that if the handbrake is only used in parked situations, then there is no wear at all on the shoes.
If you use the hand brake to slow down on a regular basis, then there will be wear.
Old Jul 15, 2016 | 07:50 PM
Most handbrake failures I see are when the linings break away from the shoes. After a number of years of hot and cold, the bonding fails.
James
Old Jul 15, 2016 | 08:33 PM
Kingdav1954's Avatar
Can you say drifting!! Lol!
Old Jul 16, 2016 | 01:01 AM
rush549's Avatar
I had one of the pads on the front come apart. The car has 55k, and still had about 50% left. Having a six speed and being a truck driver keeps brake use to a minimum.
BTW, I agree that the parking brakes should last forever. But your delamination story seems to ring true. I would still check them out before deciding they should be replaced. Waste not, want not.
Old Jul 16, 2016 | 07:54 AM
I had an E-brake shoe come loose and it allowed the car to be backed up only, when trying to go forward the pad jammed up the other shoe and stopped the car dead in its tracks after an inch or two. This was not the Xfire by the way.
bucketlisted
Sep 30, 2016 06:27 PM
elinkous
Jul 24, 2016 06:48 PM
pcarsdoc1
May 11, 2016 02:20 AM
canadablue
Apr 25, 2016 07:44 PM
Da55id
Apr 19, 2016 03:48 PM
