Raise Eibach Suspension Height
Old Jan 15, 2017 | 04:40 PM
SRT-OSO's Avatar
Default Raise Eibach Suspension Height
I'm running a 255/30R20 up front on a 9" rim. Fills out the wheel well very nicely, and I've rolled the fender lips and removed the top two screws and trimmed the liner, it's almost rub free, but I figure if I could raise the front slightly, I'd be golden. I like the EIbachs, and I'm not keen on spending $1,800 right now on KW's. Does anyone know of any kind of spring plate/shim available for the Crossfire to tune the suspension height?
Old Jan 16, 2017 | 04:45 AM
kamilspider's Avatar
Default Re: Raise Eibach Suspension Height
I running now on winter tires 235/40/18 + 255/40/19 + Vogtland lowered springs -35/-35mm
On photos empty car. With 2 pearsons is lower -5/-10mm front/rear.
For rise suspension you can use this: http://www.redmars.pl/pol_pl_Guma-po...210-1114_6.jpg (different sizes/heights for Crossfire or SLK)
Old Jan 16, 2017 | 08:38 AM
SRT-OSO's Avatar
What brand spacers are those?
Old Jan 16, 2017 | 08:44 AM
maxcichon's Avatar
There is a series of "Spring Pad"s n 4 mm increments, for the front and the rear. They are identified by a set of raised bumps on one end.
"1 dot" through "4 dot".
They fit between the top of a spring and the top spring perch, fine-tuning the ride height.
Their original purpose was to offset sag from older springs.
Search for "R170 Spring Pads".
Old Jan 16, 2017 | 08:50 AM
A2103210184 Beilage 1 Noppen 5mm Vorderachse Febi-Nr. 09284
A2103210284 Beilage 2 Noppen 9mm Vorderachse Febi-Nr. 09285
A2103210384 Beilage 3 Noppen 13mm Vorderachse Febi-Nr. 09286
A2103210484 Beilage 4 Noppen 17mm Vorderachse Febi-Nr. 09287
A2103210584 Beilage 5 Noppen 21mm Vorderachse Febi-Nr. 09288
A2103250184 Beilage 1 Noppen 5mm Hinterachse Febi-Nr. 17087
A2103250284 Beilage 2 Noppen 9mm Hinterachse Febi-Nr. 17088
A2103250384 Beilage 3 Noppen 13mm Hinterachse Febi-Nr. 17089
A2103250484 Beilage 4 Noppen 17mm Hinterachse Febi-Nr. 17090
Mercedes klasa SLK | Obni?enie zawieszenia | MERCEDES Forum
Old Jan 16, 2017 | 09:03 AM
maxcichon's Avatar
http://www.autopartswarehouse.com/sk...3-1890024.html
Old Mar 7, 2017 | 07:51 AM
Anybody know what spacer, how many mm we have stock in Crossfires?
Old Mar 31, 2017 | 04:38 AM
We have spacers nr3, 13mm in our Xfires.
Now I put nr1, 5mm. Car is little lower.
This is very good idea with spacers for springs. We can change height car about 15-20mm on front and rear.
