Shock day at my pondo
Old Apr 13, 2017 | 08:17 AM
Default Shock day at my pondo
maxcichon and I will be replacing all shocks on our 2 roadsters Sat Apr 23 at my place.
Anyone else want to do same is invited.
Old Apr 13, 2017 | 08:43 AM
maxcichon's Avatar
Default Re: Shock day at my pondo
What is a "Pondo"?
I'm not too sure I want to go there.......
Old Apr 13, 2017 | 08:52 AM
are you kidding ? pondo is my Ponderosa ( but Little Joe won't be here )
Old Apr 13, 2017 | 08:54 AM
maxcichon's Avatar
Joe said, in the other post, that he WILL be there!
Old Apr 14, 2017 | 08:51 AM
maxcichon's Avatar
I just looked at AutoZone for the KYB shocks.
$93. Each. Sheeeeesh!
Old Apr 14, 2017 | 08:58 AM
Is that what they call 'shock sticker shock'.
Old Apr 14, 2017 | 09:04 AM
punny Dave.
So, with the $40 rebate, we got 'em from the Rock for $43.25 each, less than half price of AutoZone ! ( and didn't even have to leave the farm )
BTW, got my 12mm rod end inserts in yesterday, will be swapping them out on the DIY camber links too.
Old Apr 21, 2017 | 01:02 AM
Steve Jr's Avatar
I want to know if the camber links are going to be an easy install. Last alignment, looking at it, I'm going to have to do the adjustables.
Old Apr 21, 2017 | 06:16 AM
Yes, fairly easy.
Make sure you get some of those 12 mm inserts from Iron Rock Off Road, and lube everything up good with a good suspension grease or white lithium (inserts inside and outside, poly bushings inside and outside. )
You will need : floor jack, jack stands, 2 18 mm wrenches/sockets and a T55 male Torx.
Assembly the DIY's to the same length as the removed links.
I use an air ratchet after the bolts were loosened and it saves a lot of time.
Remove the outer bolt first ( the T55 one ), when it is loose, you can put the box end of the 18 mm wrench on the nut above the one you are removing and pry out to relieve the load when extracting the bolt.
Once done, take it in for a good laser alignment.
When I replaced the inserts last weekend with the 12 mm ones it took me 2 hours total working alone, but then that made 4 times I have done it.
( my car twice, once on a 2005 coupe and once on another 2005 roadster )
Nothing like experience.
Old Apr 21, 2017 | 01:30 PM
Steve Jr's Avatar
So, if you did it in 2 hr's. That means I should be able to do it in 5 or 6 hr's. an 1 box of Band-Aids.
Old Apr 21, 2017 | 05:36 PM
JSK's Avatar
JSK
Don't forget to stock up on beer.
Old Apr 23, 2017 | 11:05 PM
lovecross's Avatar
Question Re: Shock day at my pondo
punny Dave.
Why are you installing new "12mm rod end inserts"? Was there a problem w/ Speedway parts? Thanks.
Old Apr 24, 2017 | 06:13 AM
The inserts in the Speedway ends are 1/2 ", about 1/32" larger than 12 mm.
The bolt sizes are for the OEM 12 mm sleeves, therefore the Speedway inserts leave some room for movement ( rattling ).
Old Apr 26, 2017 | 03:02 AM
lovecross's Avatar
Thank you. I have very few miles on the new parts so far. Is some rotational movement/wear to be expected w/up & down wheel movement?
Old Apr 26, 2017 | 07:25 AM
There is a very little bit of up and down movement, wear should not be an issue if you lube them up good prior to installation.
