Exact sway bar specs
Old May 16, 2018 | 09:03 PM
alexdc's Avatar
Default Exact sway bar specs
Good day everyone,
I am looking to buy new sway bar bushings on my Crossfire. Polyurethane bushings. There's one shop in Europe that offers them. Strong flex. It fits (many types of Benz for that matter) but unfortunately they ask that for the exact diameter of the anti roll bar.
I have read many threads but they all seem to specify different specs 15mm, 18mm or 20mm.
For a 2007 limited.
I don't know what to do. Any help is appreciated.
Here's the link:
https://www.strongflex.eu/en/1196-r170
Thanks
Old May 16, 2018 | 11:55 PM
Default Re: Exact sway bar specs
Amazon Amazon
and scrunch under the car
Old May 17, 2018 | 08:36 AM
Originally Posted by alexdc
Good day everyone,
For a 2007 limited.
Here's the link:
Thanks
Front, back or both?
Old May 17, 2018 | 03:00 PM
alexdc's Avatar
Front for now.
Old May 17, 2018 | 03:41 PM
Front for now.
It is 25mm, according to a forum search.
My SRT is 25mm. Maybe the SRT and NA are both 25mm with a thicker wall on the SRT.
Last edited by onehundred80; May 17, 2018 at 04:24 PM. Reason: Modified again and again.
Old May 17, 2018 | 06:32 PM
KDW4Him's Avatar
"Thicker wall"? Aren't they solid?
Old May 24, 2018 | 08:31 AM
Speedy4x4's Avatar
If I remember the N/A is 25mm, srt is 28mm and the H&R is 30mm, or 22mm, 25mm and 30mm
Old May 24, 2018 | 08:46 AM
I measured my SRT front and it is 25mm.
Old May 24, 2018 | 08:49 AM
Speedy4x4's Avatar
ok, I couldn't remember which it was, but srt is larger than on N/A
Old May 24, 2018 | 12:07 PM
alexdc's Avatar
Can anyone measure the one on the na. I don't have the tool. 😔
Old May 24, 2018 | 01:20 PM
Speedy4x4's Avatar
sorry, I don't have time this weekend.
if I remember to grab my calipers next week, I can, but with the busy weekend will probably forget.
Old May 25, 2018 | 01:33 PM
alexdc's Avatar
Thank you!
Old Jun 10, 2018 | 08:56 PM
alexdc's Avatar
Anyone can help?
Old Jul 29, 2022 | 03:07 PM
zip439's Avatar
This is an old thread, but some info about the front sway bar needs clarification:
I just installed the H&R 30mm, Part number 33769 VA, on my SRT6. I have had a H&R sway bar on my Limited for several years . Now both cars have H & R on the front.
After removal of the OEM front bar from the SRT 6 I compared it to the one I removed years ago from the Limited. It is the exact same sway bar; Both the Limited and the SRT6 from the factory have the exact same bar on the front. It is 25 mm in diameter, both part numbers on the bar are the same MB # A170 323 08 65 SCA and the part listing from Chrysler also shows the same bar and number on all Crossfires # 05098980AA. The difference in the suspension between the SRT6 and a Limited is in the coil springs and shock absorbers. There are also differences between the roadster and coupe as to springs and shocks, but the front sway bar is the same on all Crossfires.
I weighed the bars on my bathroom scale ( not all that accurate) but both OEM 25 mm bars weighed about 10 lbs and the 30mm H&R weighed about 14lbs.
From my Limited and SRT6, both coupes, part numbers same. I measured the diameter in several places along the length of the bar all are the same. I posted this pic because both parts numbers are visible
ardenian
Jul 21, 2018 12:53 PM
dayjor
20
Jan 26, 2015 07:12 PM
dayjor
Jun 6, 2014 11:20 PM
mobilefitt
Apr 17, 2014 07:46 PM
hcarter
Dec 4, 2011 09:03 AM
