Lower control arm bushing front
On both sides of my car the bushings are badly cracked and worn. Both sides need replaced.. Shop I was at said no one sells the bushings and have to replace the whole arm that sells for over $500 each.
Has anyone found a place to buy the bushings? Or perhaps a cheap set of arms?
read this thread. it may help you make a decision; https://www.crossfireforum.org/forum...-kit-help.html
Basically you can replace the entire A frame or install a K-mac kit. A third choice might be to replace your bushings with OEM, but as to price you will have to decide which is best for you; none of it is inexpensive because of the labor involved. The K-mac runs about $320
Thank you very much. I am still looking for oem replacements but the K-Mack kit might be the cheapest option.. This wont be me installing it as I don't have all the tools and other crud so I have to find a shop with a open mind.
interesting site have you ever bought from them? I will call them tomorrow
I hear a lot of talk about replacing the Front Lower Control Arms on these cars, which I will be doing without a doubt as my bushings are shot. But what about the Front *Upper* Control Arms? Are they not as crucial of a part, or do they perhaps not have rubber bushings?
Also....same questions on the rear (upper and lower) control arms. Not worth changing out?
Thanks.
Thanks.
TexasSRT
Aug 21, 2014 01:49 PM
junboy13
Oct 10, 2013 07:51 PM
PWALL
Sep 8, 2012 04:49 PM
vladd
Mar 12, 2010 02:32 PM
