Quick question on TPMS
Hi all,
We are replacing both rear tyres on my wifes Crossfire on Wednesday as one is completely illegal - RWD so swapping out in pairs. I have heard that the car has a pressure monitoring system installed, is there anything the tyre fitter needs to know as to not mess up the system? I do have an OBD2 reader which can read and reset codes - am I able to use this to reset any codes for the pressure monitoring system or it is something that will be causing me a headache in the near future? Guess that the sensor will reset the light if the pressure is correct though? Worth noting that the MOT here in the UK requires the system to be working - can't fix it with tape unfortunately! |
Re: Quick question on TPMS
Originally Posted by m1tch
(Post 907033)
Hi all,
We are replacing both rear tyres on my wifes Crossfire on Wednesday as one is completely illegal - RWD so swapping out in pairs. I have heard that the car has a pressure monitoring system installed, is there anything the tyre fitter needs to know as to not mess up the system? I do have an OBD2 reader which can read and reset codes - am I able to use this to reset any codes for the pressure monitoring system or it is something that will be causing me a headache in the near future? Guess that the sensor will reset the light if the pressure is correct though? Worth noting that the MOT here in the UK requires the system to be working - can't fix it with tape unfortunately! Make sure that the tyre installer knows there are sensors in the wheel and that he should not damage them. You will not be able to reset the TPMS with your OBD reader. |
